Home » Archived » BIRT » Show Content Footer Only on Last Page - URGENT
Show Content Footer Only on Last Page - URGENT [message #262403] Thu, 29 November 2007 13:28 Go to next message
Originally posted by: sergiogomes.uxs.pt
i have a report with 3 pages, i want show a image only on the footer of
the last page of report rendered to PDF. But the image appears in the 3
pages of the report!!
How i can resolve this problem? its Urgent
Thanks for your help.
Re: Show Content Footer Only on Last Page - URGENT [message #262422 is a reply to message #262403] Thu, 29 November 2007 17:54 Go to previous messageGo to next message
Originally posted by: johnw.innoventsolutions.com
Sergio,
Now that I get into it, I don't think there is a way to do it. The page
and total page properties aren't available until after run time and
before render time.
IIRC, the AutoText fields are just "placeholders" that get replaced at
render time. The only way I can think of doing this is to write an
emitter that write out the image reference on the last page, and only
use that emitter for that one report.
See if Jason comes back with something, if not, submit this as an
enhancement or bug.
John
sergiogomes wrote:
Re: Show Content Footer Only on Last Page - URGENT [message #262425 is a reply to message #262403] Thu, 29 November 2007 17:56 Go to previous messageGo to next message
You need to add the image to the table footer instead of adding it to
the master page.
Snjeza
sergiogomes wrote:
Re: Show Content Footer Only on Last Page - URGENT [message #262428 is a reply to message #262403] Thu, 29 November 2007 18:14 Go to previous messageGo to next message
sergiogomes wrote:
hi Sergio, I'm with Snjeza. To get it done urgently, put the whole
report in a table or a grid, and just include the image in the last row
of the grid, or the footer of the table. That will get you going for now.
Peter Robinson
Performance and Capacity Management
IBM Australia
Re: Show Content Footer Only on Last Page - URGENT [message #262490 is a reply to message #262428] Fri, 30 November 2007 15:04 Go to previous messageGo to next message
This should work, assuming there is only a single table or grid in the
report. If a single grid is put into the report, and then all
tables/grids are put in cells, with the image in a final cell, that
should do it, except it wont appear as a "page footer".
Hah, that was the first thing I tried, and completely ignored it when it
didn't duplicate the issue :)-
John
Peter Robinson wrote:
> sergiogomes wrote:
>> Hi,
>> of the last page of report rendered to PDF. But the image appears in
>> the 3 pages of the report!!
Re: Show Content Footer Only on Last Page - URGENT [message #262541 is a reply to message #262403] Mon, 03 December 2007 06:41 Go to previous messageGo to next message
Hi Sergio, I'm trying to solve exactly the same problem. I absolutely need
to have the page footer on the last page different from previous pages. If
you find any useful solution, I would appreciate the information from you.
If there was the possibility to divide BIRT document into logical sections,
similar to MS Word document sections, then it would be easy to define
different footers for different document sections. But I believe, that such
solutions hasn't been implemented yet and I don't know if it it's in
development plan or not.
JP
"sergiogomes" <sergiogomes@uxs.pt> p
Re: Show Content Footer Only on Last Page - URGENT [message #1781850 is a reply to message #262541] Tue, 13 February 2018 17:18 Go to previous message
My problem is similar, I need not to show the footer on last page. I am using MASTER/FOOTER, the option to show footer on last page=false is not working. Any idea why? Posting here because it looks to relate to this problem.
Previous Topic:How to excute Highlighting script in DynamicText or how can i run myscript for PDF report
Next Topic:MASTER/FOOTER option to show footer on last page = false not working
Current Time: Sat Jul 26 06:10:16 EDT 2025
Powered by FUDForum. Page generated in 0.06681 seconds
