Home » Eclipse Projects » Babel » Babel Pseudo Translation Test:
| Babel Pseudo Translation Test: [message #25463] |
Wed, 11 March 2009 08:44  |
I'd like to run Babel Pseudo Translation Test on Memory Analyzer
(technology.mat) to verify its translatablity, but the pseudo translation
language packs are not generated yet (In fact there was no translation for
MAT at all so far). Does Babel provide a tool to generate those pseudo
packs?
Best Regards,
Elena.
| Re: Babel Pseudo Translation Test: [message #25621 is a reply to message #25503] |
Sat, 14 March 2009 03:18   |
Originally posted by: atoulme.intalio.com
Antoine Toulme wrote:
> Elena Nayashkova wrote:
>> Hi,
>> translation language packs are not generated yet (In fact there was no
>> translation for MAT at all so far). Does Babel provide a tool to
>> generate those pseudo packs?
>> Best Regards,
>> Elena.
> Hey Elena, nice to have you on the webinar this week. We had a big bug
> with the new strings and that should be resolved over the weekend.
> What also might happen is that hte map file you provided isn't giving
> anything, ie there is a problem with it.
> In any case, I would rather discuss this through a bug. Please open one,
> I will check your map file meanwhile.
I just checked your map file and there is something wrong with it indeed
(and I know you copied it from stp.bpmn, and yes I just corrected it for
that project too, sorry!)
Your plugin reference looks like this:
plugin@org.eclipse.mat.api= SVN,trunk,http://dev.eclipse.org/svnroot/technology/org.ecli pse.mat,,trunk/plugins/org.eclipse.mat.api
instead, change it to look like this:
plugin@org.eclipse.mat.api= SVN,trunk,http://dev.eclipse.org/svnroot/technology/org.ecli pse.mat,,plugins/org.eclipse.mat.api
We now read the trunk part as the second fragment, so there is no more
need to output trunk/plugins/org.eclipse.mat.api,
plugins/org.eclipse.mat.api is enough.
Antoine
| Re: Babel Pseudo Translation Test: [message #26957 is a reply to message #26354] |
Wed, 15 April 2009 10:51  |
>>If the map file is correct the pseudo translation package should be
generated >>over the weekend, right?
> Yes. The server is down so this might take a bit longer.
The PPT plugin was not generated yet and I can't understand whether it is
because the map file is still wrong or whether there are other problems.
Another question: when I try to use translation tool for MAT it seems not
to update the sections "Strings in File" and "Traslation for Key" properly
(they stay empty). What can cause this problem?
| Re: Babel Pseudo Translation Test: [message #577312 is a reply to message #25463] |
Sat, 14 March 2009 02:36  |
> Best Regards,
> Elena.
| Re: Babel Pseudo Translation Test: [message #577382 is a reply to message #25503] |
>> Hi,
>> Best Regards,
>> Elena.
Antoine
| Re: Babel Pseudo Translation Test: [message #577482 is a reply to message #25463] |
Tue, 17 March 2009 07:44  |
I opened a bug for you:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268949
Antoine
> Best Regards,
> Elena.
| Re: Babel Pseudo Translation Test: [message #577575 is a reply to message #25463] |
Sat, 21 March 2009 11:05  |
While this test may not require multiple languages yet, please let me know
if you require help with translating or proof-reading MAT resources
(especially in German ;-)
Werner
"Elena Nayashkova" <elena.nayashkova@sap.com> schrieb im Newsbeitrag
news:55b566bddd9033a9e0f6006ccba7b9e1$1@www.eclipse.org...
> packs?
> Best Regards,
> Elena.
| Re: Babel Pseudo Translation Test: [message #577833 is a reply to message #26234] |
Thu, 02 April 2009 16:38  |
> Thanks Antoine, I've just fixed it. If the map file is correct the
> pseudo translation package should be generated over the weekend, right?
> Regards,
> Elena.
| Re: Babel Pseudo Translation Test: [message #578273 is a reply to message #26354] |
Current Time: Wed Nov 12 23:58:14 EST 2025
Powered by FUDForum. Page generated in 0.05902 seconds
