Home » Eclipse Projects » Eclipse Platform » How to contribute actions to own SWT control?
How to contribute actions to own SWT control? [message #261976] Fri, 16 July 2004 07:38 Go to next message
I have an SWT-control called 'Outline', which I want to use in my
plugin-application.
I made some wrapper called 'OutlineViewer' which extends Outline and
implements ISelectionProvider.
Then I want to add a popup-menu action which would popup when something
is selected in Outline.
Here is the View code:
public void createPartControl(final Composite aParent)
//--- cut ----
getSite().setSelectionProvider(m_OutlineViewer);
createContextMenu();
private void createContextMenu()
MenuManager menuMgr = new MenuManager();
menuMgr.setRemoveAllWhenShown(true);
menuMgr.addMenuListener(new IMenuListener()
public void menuAboutToShow(IMenuManager mgr)
fillContextMenu(mgr);
Menu menu = menuMgr.createContextMenu(m_OutlineViewer.getCanvas());
m_OutlineViewer.getCanvas().setMenu(menu);
// Register menu for extension.
getSite().registerContextMenu(menuMgr, m_OutlineViewer); }
private void fillContextMenu(IMenuManager mgr)
mgr.add(new GroupMarker(IWorkbenchActionConstants.MB_ADDITIONS));
OutlineViewer implements all neccesary methods, and they are even called
by the framework when i make a right-click on my viewer :-)
The problem is that menu manager doesnt get selection from the control,
though 'getSelection' method is called and always returns a consistent
object instance.
The action contribution is 100% correct: when i use the TableViewer
class instead of my viewer everything works fine...
What can be wrong?
Thank you,
Ilya
Re: How to contribute actions to own SWT control? [message #262090 is a reply to message #261976] Fri, 16 July 2004 13:33 Go to previous messageGo to next message
> plugin-application.
Try asking in eclipse.platform.swt.
Re: How to contribute actions to own SWT control? [message #262295 is a reply to message #262090] Mon, 19 July 2004 07:00 Go to previous message
The soultion was to implement IStructuredSelection interface (but not
ISelection) for the selection object.
>> plugin-application.
Previous Topic:problem with preference page
Next Topic:Location of extension objects
Current Time: Fri Jul 25 12:13:08 EDT 2025
Powered by FUDForum. Page generated in 0.04983 seconds
