Home » Language IDEs » Java Development Tools (JDT) » ITypeParameter bounds names are not signatures
ITypeParameter bounds names are not signatures [message #261322] Wed, 22 July 2009 05:04 Go to next message
I am analysing the Java Model and in particular the type parameters of
IType & IMethod.
Why does the names of the bounds of a ITypeParameter are not signatures ?
For example,
in source :
public class P<E extends List<Integer>> {
public <T extends Thread & List<String>> void Test(){
In class file :
The bound of the ITypeParameter of the IType P will be :
java.util.List<java.lang.Integer>
The bounds of the ITypeParameter of the IMethod Test will be :
java.lang.Thread
java.util.List<java.lang.String>
That's a problem since we can't use org.eclipse.jdt.core.Signature methods.
Sorry for bad english.
Re: ITypeParameter bounds names are not signatures [message #261341 is a reply to message #261322] Wed, 22 July 2009 10:22 Go to previous messageGo to next message
Found the reason :
in the method generateTypeParameterInfos of the class
org.eclipse.jdt.internal.core.ClassFileInfo, the type parameters
signatures are translated :
for (int j = 0; j < boundLength; j++) {
typeParameterBounds[j] =
Signature.toCharArray(typeParameterBoundSignatures[j]);
CharOperation.replace(typeParameterBounds[j], '/', '.');
If nobody replies, i think i will open a bug.
Romain Dervaux a écrit :
> Hi
> IType & IMethod.
> For example,
> in source :
> In class file :
> java.lang.Thread
Re: ITypeParameter bounds names are not signatures [message #261345 is a reply to message #261341] Wed, 22 July 2009 11:08 Go to previous messageGo to next message
> Found the reason :
If you want signatures, you should use
org.eclipse.jdt.core.IType.getTypeParameterSignatures() or
org.eclipse.jdt.core.IMethod.getTypeParameterSignatures() even if the
latte one is deprecated.
Olivier
Re: ITypeParameter bounds names are not signatures [message #261386 is a reply to message #261345] Mon, 27 July 2009 09:29 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=246594
Markus
Previous Topic:Java Model to IBinding ?
Next Topic:Tag lib auto-completion and subdived project?
Current Time: Mon Nov 03 03:19:10 EST 2025
Powered by FUDForum. Page generated in 0.07390 seconds
