Home » Modeling » TMF (Xtext) » [TCS] Injector ATL dependency
[TCS] Injector ATL dependency [message #2442] |
Fri, 22 February 2008 06:25  |
I like the way you made most of the code independent from atl.engine code,
as IMO this dependency should be contained in ASMModelAdapter alone.
However, there are still dependencies in TCSInjector.
For me, it would be ideal if basically the whole
org.eclipse.gmt.tcs.injector project had no references at all to atl
libraries, as we would be able to generate Injectors that are independent
from atl that way, and if we do not want to use the ASMModelHandler, we
would not need this dependency.
Also, to my very personal subjective taste, it would be great to have the
parameters used in TCSInjector.inject() in a Bean rather than a map, to
make the interface explicit. Also, for the problems model
ASMModel problems = (ASMModel)params.get("problems");
introduces a kind of dependency that is hard for me to tackle if I want to
avoid using ASMModel. Could this be replaced or wrapped in some interface?
I guess you are working on these things anyways, so don't think of this as
a critique, I think you are doing a great job.
Re: [TCS] Injector ATL dependency [message #2528 is a reply to message #2442] |
Sat, 23 February 2008 09:25   |
TCSInjector is the ASMModel-based API to call TCS. During the recent
improvements, we created ParserLauncher, which is the generic API.
Therefore, I would suggest that you write your own injector class that
will use your own ModelAdapter, and invoke ParserLauncher. As you can
see in TCSInjector.java (almost empty now that the generic part has been
extracted), this is quite easy to do.
Frédéric Jouault
Thibault a écrit :
> code, as IMO this dependency should be contained in ASMModelAdapter alone.
> independent from atl that way, and if we do not want to use the
> ASMModelHandler, we would not need this dependency.
> the parameters used in TCSInjector.inject() in a Bean rather than a map,
> to make the interface explicit. Also, for the problems model
> to avoid using ASMModel. Could this be replaced or wrapped in some
> interface?
> as a critique, I think you are doing a great job.
Re: [TCS] Injector ATL dependency [message #2557 is a reply to message #2528] |
Mon, 25 February 2008 04:52   |
Hi Frédéric,
I can indeed, my problem is that in the TCS2ANTLR.ATL script, a generated
parser will always have
public org.eclipse.gmt.tcs.injector.TCSRuntime ei = null;
thus there is a compile time dependency to your implementation of an
injector and thus to the ASMModel-based API.
If TCSInjector was just a java-interface, shipped in a bundle without
ASM-Model dependencies, separation of concerns (Injector generation vs.
which Modelling API to use) would appear to be better to me.
Re: [TCS] Injector ATL dependency [message #2586 is a reply to message #2557] |
Mon, 25 February 2008 06:47   |
We separared the old TCSInjector into the new TCSInjector,
ParserLauncher, and TCSRuntime. The objective is to make injection
possible with only ParserLauncher, and TCSRuntime, which do not depend
on the ASMModel-based API any more.
You only need ParserLauncher and TCSRuntime to make an injector with a
different ModelAdapter. If we missed some dependency from TCSRuntime to
the ASMModel-based API, please tell us so that we can remove it.
Frédéric Jouault
Thibault a écrit :
> Hi Frédéric,
>> been extracted), this is quite easy to do.
> generated parser will always have
Re: [TCS] Injector ATL dependency [message #2641 is a reply to message #2613] |
Mon, 25 February 2008 11:57  |
Hi Thibault,
> I am sorry, what I wrote did not make any sense. I thought you still
> used TCSInjector instead of TCSRuntime, even though in the part I cited
> TCSRuntime was being used. I just need some glasses.
> thanks for your patience,
You are welcome.
Please let us know about your progress :-).
Frédéric Jouault
Current Time: Fri Jul 18 06:18:33 EDT 2025
Powered by FUDForum. Page generated in 0.52292 seconds
