| Plug-in migration from 2.1 to 3.0. [message #259242] |
Wed, 07 July 2004 11:25  |
Originally posted by: zaitao.li.ca.com
I am migrating our plug-in project from 2.1 to 3.0. I have used the PDE
migration tool, after that everything seems fine. My plug-in works fine
except there are some warnings at compile time with regard to deprecated
functionalities in 3.0.
So I started to change my code to get rid off the warnings, one of them is
the plugin constructor:
It's used to be:
public class MyPlugin extends Plugin
private static MyPlugin s_plugin;
* Constructor for MyPlugin.
public CAHCorePlugin(IPluginDescriptor descriptor)
super(descriptor);
s_plugin = this;
| Re: Plug-in migration from 2.1 to 3.0. [message #259260 is a reply to message #259242] |
Wed, 07 July 2004 11:48   |
It's used to be:
public MyPlugin(IPluginDescriptor descriptor)
super(descriptor);
s_plugin = this;
Since IPluginDescriptor and the constructor MyPlugin(IPluginDescriptor)
are deprecated, I changed the above to:
public MyPlugin()
super();
s_plugin = this;
After the change, the project is built fine. But at run time, eclipse is
not able to initiate my plugin, it seems eclipse is still looking for the
older constructor, I know I may missing something trivial here, but what
am I missing?
Following is the error dump in eclipse:
java.lang.NoSuchMethodException:
com.me.MyPlugin.<init>(org.eclipse.core.runtime.IPluginDescriptor)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.getConstructor(Unknown Source)
at
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:403)
at
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:359)
at
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:328)
at
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:47)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:293)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:110)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.requir eClass(BundleLoader.java:336)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredClass(BundleLoader.java:914)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
at
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:307)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:336)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1313)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:131)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:196)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:51)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:193)
at
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:83)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:79)
at
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:153)
at
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 60)
at
at
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:258)
at
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:241)
at
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:264)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
| Re: Plug-in migration from 2.1 to 3.0. [message #260838 is a reply to message #260263] |
Mon, 12 July 2004 14:06  |
Originally posted by: chaves.nospam.inf.ufsc.br.ok
Try launching Eclipse with -clean.
Richard wrote:
> I have checked the source for sample helloworld plug-in and can not see
> any difference between my plugin and the sample.
> An even stranger thing I found out is that, my plug-in runs perfect if I
> run it from my eclipse project. But if I use the eclipse export
> functionality to export the plugin and copy it to the plugins directory in
> eclipse, the problem will occur.
> Wassim Melhem wrote:
> > Moving off the core.runtime.compatibility dependency is not a requirement
> > in 3.0.
> > However, if you choose to do so, as you have noticed, you will have to
> > modify the code in your plug-in's top-level Java class.
> > I suggest you generate a sample Hello World plug-in project using PDE,
> > examine what the generated code for this sample plug-in's class looks like
> > and do the same for your plug-in.
> > Wassim.
> > Richard wrote:
> > > Ed Burnette wrote:
> > > > This may or may not help but the doc says to import
> > > > and not org.eclipse.osgi.* .
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/org.ecli pse.platform.doc.isv/porting/eclipse_3_0_porting_guide.html
> > > I have also imported org.eclipse.core.runtime in my plugin.xml.
FUDForum. Page generated in 0.05165 seconds
