Home » Language IDEs » Java Development Tools (JDT) » Correct instantiation and configuring of JavaSourceViewer
Correct instantiation and configuring of JavaSourceViewer [message #260656] |
Tue, 16 June 2009 15:24  |
Hi, I've got a little problem. I'm trying to create view in my plug-in,
which will contain Java editor with syntax highlighting and other stuff.
For this task I decided to use
org.eclipse.jdt.internal.ui.javaeditor.JavaSourceViewer.
Here is fragment of code from the
createPartControl(org.eclipse.swt.widgets.Composite) method of my view:
IPreferenceStore store = new ScopedPreferenceStore(new InstanceScope(),
Activator.getDefault().getBundle().getSymbolicName());
int styles = SWT.V_SCROLL | SWT.H_SCROLL | SWT.MULTI | SWT.BORDER |
SWT.FULL_SELECTION;
JavaSourceViewer viewer = new JavaSourceViewer(parent, null, null, false,
styles, store);
Activator is a main class of my plug-in (extends from AbstractUIPlugin).
This fragment works fine, except 2 things. First, I can't see text I set
such way:
viewer.getTextWidget().setText("sdlfknjhsadkjlfhn,skdf");
I've explored code of method and decided to change it to:
viewer.getTextWidget().getContents().setText("sdlfknjhsadkjlfhn,skdf ");
(text widget's setText() method have a lot of intermediate code, event
handling, etc and I think its incorrect to do it my way, in contravention
of widget's setText())
And second. As I understood, syntax highliting and other such behavior are
provided by JavaSourceViewerConfiguration class.
JavaSourceViewerConfiguration configuration =
new JavaSourceViewerConfiguration(new JavaColorManager(), store,
this, IJavaPartitions.JAVA_PARTITIONING);
viewer.configure(configuration);
But when I'm tryed to instantiate it and configure viewer with it, I've
got an NPE:
at
org.eclipse.jdt.ui.text.JavaSourceViewerConfiguration.getSet tings(JavaSourceViewerConfiguration.java:813)
at
org.eclipse.jdt.ui.text.JavaSourceViewerConfiguration.getCon tentAssistant(JavaSourceViewerConfiguration.java:392)
at
org.eclipse.jface.text.source.SourceViewer.configure(SourceV iewer.java:370)
at
org.eclipse.jdt.internal.ui.javaeditor.JavaSourceViewer.conf igure(JavaSourceViewer.java:223)
at
com.codesrc.thinktankrcp.projects.FileContentsView.createPar tControl(FileContentsView.java:161)
So, I've investigated it and saw that
org.eclipse.jdt.internal.ui.JavaPlugin.getDefault() in
JavaSourceViewerConfiguration.java:813:
IDialogSettings settings=
JavaPlugin.getDefault().getDialogSettings().getSection(secti onName);
returned null. Also I tryed to experiment with
org.eclipse.jdt.internal.ui.javaeditor.JavaEditor and got a lot of similar
NPE in same situations from such classes:
org.eclipse.jdt.internal.ui.JavaPlugin,
org.eclipse.ui.internal.editors.text.EditorsPlugin,
org.eclipse.jdt.core.JavaCore. I've tried to fill it's values by
reflection :), it works, but at first it's a terrible ugly hack, and in
second - I've started to receive many other exceptions in many places, so
it is not correct way. As I understood, something in the Eclipse Platform
should correctly initialize, prepare and tune such classes. Can you help
me with it? Maybe I should differently set up my plug-in project, include
some dependencies to it or something else?
Re: Correct instantiation and configuring of JavaSourceViewer [message #260671 is a reply to message #260656] |
Wed, 17 June 2009 03:56   |
> plug-in, which will contain Java editor with syntax highlighting and
> other stuff. For this task I decided to use
Note that this is an internal class which you should not use (try
SourceViewer instead). Having said that, it looks like for some reason
the org.eclipse.jdt.ui plug-in is not loaded and hence you get the NPE.
Make sure that plug-in is listed as required plug-in in your plug-in.
Dani
> SWT.FULL_SELECTION;
> false, styles, store);
> AbstractUIPlugin). This fragment works fine, except 2 things. First, I
> can't see text I set such way:
> contravention of widget's setText())
> are provided by JavaSourceViewerConfiguration class.
> JavaSourceViewerConfiguration configuration = new
> JavaSourceViewerConfiguration(new JavaColorManager(), store, this,
> I've got an NPE:
> at
> at
> at
> at
> at
> similar NPE in same situations from such classes:
> in second - I've started to receive many other exceptions in many
> places, so it is not correct way. As I understood, something in the
> Eclipse Platform should correctly initialize, prepare and tune such
> classes. Can you help me with it? Maybe I should differently set up my
> plug-in project, include some dependencies to it or something else?
Re: Correct instantiation and configuring of JavaSourceViewer [message #260777 is a reply to message #260742] |
Tue, 23 June 2009 12:25  |
Well, I've solved the problem. After adding of all required package
bundles to the MANIFEST.MF through the "Plug-in Manifest Editor" I went to
the "Debug Configurations..." -> "Plug-ins", removed all plug-ins by
pressing "Deselect All" and then added all required by pressing "Add
Required Plug-ins". After it troubles during plug-in start in Debug mode
are gone. Now files opens correctly on active page using
CompilationUnitEditor (JavaUI.ID_CU_EDITOR). Thanks again for your replies.
Alexander.
Current Time: Wed Sep 17 21:00:32 EDT 2025
Powered by FUDForum. Page generated in 0.04875 seconds
