Home » Eclipse Projects » Eclipse Platform » NoClassDefFoundError 3.0 RCP Application
NoClassDefFoundError 3.0 RCP Application [message #259998] Fri, 09 July 2004 00:34 Go to next message
Originally posted by: matt.agtown.com
I hope someone out there may be able to help. I have developed an RCP
application for Eclipse 3.0. The application works great while in the ide
workbench using run... and debug...; I have moved the plugin and all
required
plugins to the RCP Runtime Binary downloaded from eclipse.org. I have
changed
the config.ini appropriatly for my RCP Application. However the
application no
longer works correctly. The application starts, but when it requires a
class
from xmlrpc-1.2-b1.jar it throws an exception. One of the libraries that
it
depends on cannot be found in the classpath. I have tried including this
library in many ways:
1. As a required plugin
2. As a .jar file required by the plugin.xml
Neither solution seems to work.
Here is my Manifest.mf...
Manifest-Version: 1.0
Bundle-Name: App Plug-in
Bundle-SymbolicName: com.agtown.edms.remote.app
Bundle-Version: 1.0.0
Bundle-ClassPath: app.jar,lib/xmlrpc-1.2-b1.jar
Bundle-Vendor: AGTOWN
Bundle-Localization: plugin
Eclipse-AutoStart: true
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.ui,
hsqldb.core
Here is the information from the log....
!SESSION Jul 08, 2004 18:28:38.341
eclipse.buildId=unknown
java.version=1.4.2_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.ui 4 4 Jul 08, 2004 18:28:38.342
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Jul 08, 2004 18:28:38.346
!MESSAGE org/apache/xmlrpc/XmlRpcException
!STACK 0
java.lang.NoClassDefFoundError: org/apache/xmlrpc/XmlRpcException
at
com.agtown.edms.remote.app.views.LoginView.loginNow(LoginVie w.java:213)
at com.agtown.edms.remote.app.views.LoginView.access$0
(LoginView.java:189)
at
com.agtown.edms.remote.app.views.LoginView$4.handleEvent(Log inView.java:157)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:954)
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2595)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2298)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at
com.agtown.edms.remote.app.edmsApplication.run(edmsApplicati on.java:30)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
I am running Suse 9.1 Linux with SunJava 1.4.2 and Eclipse 3.0
I have also tried the application on Windows XP in the RCP Runtime Binary
for
Windows. It also does not work.
Any immediate help would be appreciated.
Matt
Re: NoClassDefFoundError 3.0 RCP Application [message #260755 is a reply to message #259998] Mon, 12 July 2004 11:36 Go to previous message
Originally posted by: chaves.nospam.inf.ufsc.br.ok
When running from inside the IDE, how is the mentioned class provided?
Also, beware that when running Eclipse, manual changes to existing plugin
manifests will not be detected - running with -clean does the trick.
Rafael
> required
> changed
> application no
> class
> it
> org.eclipse.ui,
> hsqldb.core
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> for
> Matt
Previous Topic:how to write data to an IFile?
Next Topic:SWT within Swing application?
Current Time: Sat Oct 25 04:53:02 EDT 2025
Powered by FUDForum. Page generated in 0.06190 seconds
