Home » Eclipse Projects » Eclipse Platform » Propertyview without using IAdaptable in the core model
Propertyview without using IAdaptable in the core model [message #259848] Thu, 08 July 2004 15:42 Go to next message
Hi everybody,
how is it possible to display my model elements in the propertyview?
The thing is that I cannot implement the IAdaptable interface in my model
elements.
However I implemented an AdapterFactory that handles the getAdapter calls
for
a given model element.
I register my model element in the factory like that...
Platform.getAdapterManager().registerAdapters (this, UMLClass.class);
then in my getAdapter implemantation I did the following...
if (adaptableObject instanceof UMLClass && adapterType.equals
(UMLClassAdapter.class))
return new UMLClassAdapter ((UMLClass) adaptableObject);
I modified also the getAdapterList method...
public Class[] getAdapterList()
return new Class[]{ IPropertySource.class,UMLClassAdapter.class};
However the getAdapter method is never called when I click on the EditPart
for the model element...
Does anyone has an idea?
Thank's in advance...
Pet
Re: Propertyview without using IAdaptable in the core model [message #279968 is a reply to message #259848] Wed, 26 January 2005 07:49 Go to previous message
One possible solution would include creating a wrapper class that
implements IAdaptable interface (way simplified):
public class AdaptableDecorator implements IAdaptable {
public Object adaptable;
public Object getAdapter(Class adapter) {
if (adapter.isInstance(adaptable)) return adaptable;
return Platform.getAdapterManager()
.getAdapter(adaptable, adapter)
Then - whenever You need to add adaptable behavior for Your model
objects, You just wrap them within AdaptableDecorator.
Peter T wrote:
> Hi everybody,
> elements.
> for
> Pet
Roland Tepp
Previous Topic:High Level Eclipse Component Model Diagrams
Next Topic:Eclipse startup times
Current Time: Mon Nov 03 12:58:07 EST 2025
Powered by FUDForum. Page generated in 0.03609 seconds
