Home » Newcomers » Newcomers » Installation problem on Windows XP
Installation problem on Windows XP [message #259303] |
Thu, 26 June 2008 08:52  |
Originally posted by: 4cs6fcg02.sneakemail.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigE4FF0F4DA0C8583F027935F9
Content-Transfer-Encoding: quoted-printable
As promised, another post describing my problems on Windows.
I installed a fresh Windows XP. Did all the updates, to SP3 etc.=20
Installed quite a lot of additional software (OpenOffice, Firefox,=20
MingW, Putty, =E2=80=A6)
Downloaded Ganymede. Ran it, installed some extra packages (CDT, JDT,=20
WST, Subclipse, Texlipse, Dutch language pack). Everything fine.=20
Checked out some of my projects from svn, did some configuruing.
I then edited my user privileges, making myself non-privileged user. (I=20
suppose this is irrelevant, but you never know.)
Restarted WinXP once more to get install yet another update. After=20
restart, whenever I try to open Eclipse, I see the splash screen flash=20
by, and that=E2=80=99s it. Tried several different ways of starting it, =
no effect.
Installed it in a new location, downloaded another package, even=20
downloaded a 3.3.1 build, all the same: short flash of the splash=20
screen, then nothing.
I am out of ideas what I could do now. I am at the point of erasing the =
whole Windows installation and starting it all again, this time waiting=20
meticulously until all updates are finished before installing another=20
program or anything.
Any ideas?
Where does Eclipse store the information which workspace to use by=20
default? I have this slight impression the projects in the workspace=20
are the culprit.
Cheers, H.
--=20
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.9 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iEYEARECAAYFAkhjkRMACgkQe+7xMGD3itT9qwCeLc+BjT8b0SO1XcAQcIak qhm4
YdcAn3xMZDimhT/kqqxR2GuhgBkYTsSf
=lCSF
-----END PGP SIGNATURE-----
--------------enigE4FF0F4DA0C8583F027935F9--
Re: Installation problem on Windows XP [message #259324 is a reply to message #259303] |
Thu, 26 June 2008 12:52   |
Just wondering why you would make yourself a non-privileged user. Many
program require the user to have admin rights. I don't know if Eclipse
is such a program, but you might want to give that a try.
Paul
> MingW, Putty, …)
> by, and that’s it. Tried several different ways of starting it, no effect.
> Any ideas?
> are the culprit.
> Cheers, H.
Re: [solved?] Installation problem on Windows XP [message #259415 is a reply to message #259408] |
Fri, 27 June 2008 10:30   |
--------------enig950702EAD592C42F1A4342D2
I think I have found it. There was something wrong with the Java.=20
After reinstalling Java and Eclipse, things seem to be working now.
I still have myself as non-privileged user, only an admin-account to do=20
program installation.
Hendrik Maryns schreef:
> Michael Pellaton schreef:
>> What you are doing is a so called "multi-user installation":
>> http://help.eclipse.org/ganymede/index.jsp?topic=3D/org.ecli pse.platfo=
rm.doc.isv/reference/misc/multi_user_installs.html=20
>=20
> That site wasn=E2=80=99t very helpful. Well, yes, I now know what the =
> configuration directory is for, but the problem persists.
>> Some time ago I had similar issues under Linux and the solution
>> was quite simple:
>> - Make sure the entire eclipse installation is not writable by users
>=20
> Hm, how to do this on Windows?
Let=E2=80=99s see if it suffices to put Eclipse in c:/Program Files (actu=
ally,=20
c:/Programme on my German Windows) and make all other users non-privilege=
d.
>> - Eclipse must never be run by any user having write access to its
>> installation directory (will spoil the configuration subdirectory).
>=20
> On my Linux system, I install plugins by running Eclipse as root, then =
I=20
> get them myself as well. So at least the privileged user can get acces=
s=20
> there.
Thanks again, H.
--=20
Hendrik Maryns
http://aouw.org
iEYEARECAAYFAkhk+YkACgkQe+7xMGD3itRDFwCdEpwRF6Ee/7dTeDrTgd/W 579H
u54An1FtodDliMwod9QIC/omTQy907Lj
=VWqw
--------------enig950702EAD592C42F1A4342D2--
Re: Installation problem on Windows XP [message #259770 is a reply to message #259733] |
Wed, 02 July 2008 08:24  |
Dave Wegener schreef:
> Your launch configuration includes a reference to a file in your project.
> Since the absolute location of the file contains a space, this is what is
> causing the problem. You need to enclose the library path reference in
> quotes. Try adding this to the VM Arguments section of your launch config
> (notice the quotes):
> -Djava.library.path="${resource_loc:/MonaSearch/libraries}"
> or
> "-Djava.library.path=${resource_loc:/MonaSearchlibraries}"
> BTW, all of your posts show up in my news reader as attachments. That is
> why I didn't quote your entire message.
Thanks you very much. This was indeed the problem.
In the mean time, I also found out how to compile my JNI with MinGW, and
everything is working now. JAY!!
I really have to write all this stuff down somewhere.
Cheers, H.
Hendrik Maryns
http://aouw.org
Current Time: Tue Sep 16 13:00:50 EDT 2025
Powered by FUDForum. Page generated in 0.10086 seconds
