Headless build of features with a different folder name [message #25891] |
Wed, 08 October 2008 12:17  |
Hi all,
I would like to know how I can headless build features
(com.company.feature1,...) which are located in folders like
com.company.feature1.feature (...)?
The allElements.xml template tells to set the pluginPath property but how?
where?
Can I set this property several times, for each of my features?
I'm very far from being an Eclipse expert, but I have the bad feeling that
people in charge of Eclipse and people in charge of the PDE don't talk to
together.
Thanks for your help.
Re: Headless build of features with a different folder name [message #37410 is a reply to message #37206] |
Fri, 12 December 2008 10:48  |
Yes pluginPath works. Its value is a File.pathSeparator separated list
of directories. These directories can be:
- an eclipse directory containing "plugins" and "features" subdirectories
- the project directory for a plugin or feature
- a workspace-like directory which contains projects for plugins and
features.
Note that stated earlier in this thread, pluginPath won't help in the
case where the top level feature that you are building has a feature-id
that does not match the project name.
Prashanto Chatterjee wrote:
> Hi Andrew,
> I have just finished the exercise on the pde headless build and try as much
> as I can I couldn't get the 'pluginPath' property to work. I tried a lot
> many combinations but did not get the expected results. I got around it by
> copying my features and plugins into the 'buildDirectory' first.
> Does the pluginPath property actually work and if yes what should be the
> target value for it?
> Regards,
> Prashanto
> "Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
> news:gclf4e$pu9$1@build.eclipse.org...
>> There is no general requirement for the project name to match the feature
>> name. The single exception to this is the level feature that you are
>> specifying in the allElements.xml. In this case, if the project name and
>> feature name do not match, then you will need to set
>> "elementPath" which can be done in the allElements delegator task:
>> <target name="allElementsDelegator">
>> <ant antfile="${genericTargets}" target="${target}">
>> <property name="type" value="feature" />
>> <property name="id" value="com.foo" />
>> <property name="elementPath"
>> value="${buildDirectory}/features/com.foo-feature" />
>> </ant>
>> </target>
>> Or you can also set it in the build configuration's build.properties file.
>> This is also where you would set the pluginPath. Note that setting
>> pluginPath wouldn't actually help you in this case.
>> -Andrew
>> romu wrote:
>>> Hi all,
>>> how? where?
>>> that people in charge of Eclipse and people in charge of the PDE don't
>>> talk to together.
Re: Headless build of features with a different folder name [message #582516 is a reply to message #25891] |
Thu, 09 October 2008 13:30  |
feature name. The single exception to this is the level feature that
you are specifying in the allElements.xml. In this case, if the project
name and feature name do not match, then you will need to set
</ant>
</target>
-Andrew
romu wrote:
> Hi all,
> how? where?
> talk to together.
Re: Headless build of features with a different folder name [message #586998 is a reply to message #25932] |
Fri, 12 December 2008 00:23  |
Originally posted by: prashanto.chatterjee.gmail.com
Hi Andrew,
Prashanto
> </ant>
> </target>
> -Andrew
> romu wrote:
>> Hi all,
>> how? where?
>> talk to together.
Re: Headless build of features with a different folder name [message #587077 is a reply to message #37206] |
features.
> Hi Andrew,
> Regards,
> Prashanto
>> </ant>
>> </target>
>> -Andrew
>> romu wrote:
>>> Hi all,
>>> how? where?
>>> talk to together.
FUDForum. Page generated in 0.23336 seconds
