Home » Language IDEs » Java Development Tools (JDT) » Code Assist on Method Calls - How to get the target variable?
Code Assist on Method Calls - How to get the target variable? [message #259124] Thu, 19 March 2009 08:06 Go to next message
I'm trying to filter method call proposals of the JDT code completion
based on several critieria. For this filtering I need access to the local
variable (name and type) for which the code completion has been triggered.
However, it seems to me that there is no straight forward way to get
access to this information. Am I right? Currently, I resolve the ASTNode
at the current cursor position using the internal NodeFinder API and try
to resolve the target variable by visting the neighboring ASTNodes
manually. This is not working in all cases and I'm now asking for a better
way how to get the reference to the local variable type *and* name.
My current code to determine the target variable of a method completion
request looks as follows:
final ICompilationUnit cu = context.getCompilationUnit();
final int offset = context.getInvocationOffset();
final CompilationUnit ast = ASTResolving.createQuickFixAST(cu, null);
final char[] token = context.getCoreContext().getToken();
ASTNode n = NodeFinder.perform(ast, offset - token.length, token.length);
String varName = null;
Itype varType = null;
outer: while (n != null)
switch (n.getNodeType())
case ASTNode.BLOCK:
// case statements for all relevant ASTNode types
// which might help to resolve varName & varType.
// end of while:
if (var.name != null)
break;// while
n = n.getParent();
} // do it again with the parent node until
//we are able to resolve the variable
Summarized, is there a better solution to get values for
"String varName" & "IType varType" ?
Thanks and all the best,
Marcel
Re: Code Assist on Method Calls - How to get the target variable? [message #259158 is a reply to message #259124] Fri, 20 March 2009 04:32 Go to previous messageGo to next message
Marcel Bruch wrote:
> local variable (name and type) for which the code completion has been
> triggered.
Note that code completion has to be fast. Creating an AST for that is
not a good idea.
Dani
> ASTNode at the current cursor position using the internal NodeFinder
> API and try to resolve the target variable by visting the neighboring
> ASTNodes manually. This is not working in all cases and I'm now asking
> for a better way how to get the reference to the local variable type
> *and* name.
> completion request looks as follows:
> case ASTNode.BLOCK:
> // case statements for all relevant ASTNode types // which might help
> // end of while:
> break;// while
> n = n.getParent();
> } // do it again with the parent node until //we are able to resolve
> the variable
> Summarized, is there a better solution to get values for "String
> Marcel
Re: Code Assist on Method Calls - How to get the target variable? [message #259170 is a reply to message #259158] Sat, 21 March 2009 14:10 Go to previous messageGo to next message
Hi Daniel,
> not a good idea.
Thanks for your reply. I'm aware of performance issues. Currently, our
proposal engine needs 0.1 up to 0.2 seconds. However, the tool we are
developing is a prototype for a novel Eclipse code assist system that
filters method calls that are irrelevant for a given local variable.
Wether or not a proposal is irrelevant is decided based on some context
information like method calls previously invoked on this local variable
etc. Thus, I need access to the local variable somehow... (unfortunately).
If you want to know little more about the project and the idea behind this
post, please visit http://www.stg.tu-darmstadt.de/research/core/ and
install the current prototype from the Eclipse update site available under
http://cage.st.informatik.tu-darmstadt.de/frameworks/core/. If you are
interested in some performance numbers how well the system can filter
irrelevant method calls at the moment, drop me a line. I can provide some
statistics for the current alpha version of the Eclipse code recommender.
Anyway, my question remains. Is there a way to obtain the required
information w/o reducing the performance too much with some internal
Eclipse API? Thank you again for your help.
All the best,
Marcel
Re: Code Assist on Method Calls - How to get the target variable? [message #259182 is a reply to message #259170] Sun, 22 March 2009 16:38 Go to previous messageGo to next message
Originally posted by: alamothe.ptt.yu
I noticed that java completion proposals obtain the AST this way:
private CompilationUnit getASTRoot(ICompilationUnit compilationUnit) {
return SharedASTProvider.getAST(compilationUnit, SharedASTProvider.WAIT_NO,
new NullProgressMonitor());
Perhaps this is faster than your original approach
Marcel Bruch wrote:
> Hi Daniel,
>> not a good idea.
> context information like method calls previously invoked on this
> local variable etc. Thus, I need access to the local variable
> this post, please visit http://www.stg.tu-darmstadt.de/research/core/
> and install the current prototype from the Eclipse update site
> available under
> are interested in some performance numbers how well the system can
> filter irrelevant method calls at the moment, drop me a line. I can
> provide some statistics for the current alpha version of the Eclipse
> code recommender.
> All the best,
> Marcel
Re: Code Assist on Method Calls - How to get the target variable? [message #259199 is a reply to message #259182] Mon, 23 March 2009 04:04 Go to previous messageGo to next message
Hi Nikola,
things shifted a bit ;) My central issue (yet :)) is not the performance
but how to get the receiver of a proposal and its name - in a more
reliable way than I do at the moment. That means, I want to get rid of the
manual AST traversal after obtaining the current node to find the recevier
(the "outer: while (n != null) { switch n.getNodeType()"-stuff as
described in the first email).
Since Eclipse code completion at least extracts the type of the variable
to compute its method proposals, my initial thought was that (i) there
might be an internal API that gives me the receiver of a completion, (ii)
there is some code in Eclipse that extracts the receiver variable somehow
which might be a good starting example, or (iii) its already there but I
didn't find it. How does Eclipse solve this issue for its own code
completion?
Marcel
Re: Code Assist on Method Calls - How to get the target variable? [message #259207 is a reply to message #259199] Mon, 23 March 2009 22:38 Go to previous messageGo to next message
You can start looking from ICompilationUnit.codeComplete(...) to see how
eclipse computes core proposals, but I guess it's one enormous class which
handles every case imaginable :-)
Marcel Bruch wrote:
> Hi Nikola,
> performance but how to get the receiver of a proposal and its name -
> in a more reliable way than I do at the moment. That means, I want to
> get rid of the manual AST traversal after obtaining the current node
> to find the recevier (the "outer: while (n != null) { switch
> n.getNodeType()"-stuff as described in the first email).
> variable to compute its method proposals, my initial thought was that
> (i) there might be an internal API that gives me the receiver of a
> completion, (ii) there is some code in Eclipse that extracts the
> receiver variable somehow which might be a good starting example, or
> (iii) its already there but I didn't find it. How does Eclipse solve
> this issue for its own code completion?
> Marcel
Re: Code Assist on Method Calls - How to get the target variable? [message #259259 is a reply to message #259207] Fri, 27 March 2009 05:29 Go to previous message
Got things running. To close this thread:
org.eclipse.jdt.internal.codeassist.CompletionEngine &
org.eclipse.jdt.internal.codeassist.complete.CompletionParse r
solved my problem. The CompletionParser gives you a special ASTNode (in
field AssistParser.assistNode) which contains all required information
(var name, type, completion context etc.).
It's fast, it's reliable, it's fine - it's internal :( We will see
whether or not this internal dependency will cause problems in 3.5. Maybe
it is an option to make this part of an public API? By providing something
like an "Proposal Participant" Extension point? However, I'm fine with
this solution right now.
Thanks for the discussion and all the best,
Marcel
Previous Topic:"Run As > JUnit Test" on inherited test method
Next Topic:Dynamically loading and executing junit testcase from plugin
Current Time: Sun Nov 09 18:18:31 EST 2025
Powered by FUDForum. Page generated in 0.03918 seconds
