Use package from subclipse plugin [message #258490] |
Fri, 13 June 2008 10:05  |
Originally posted by: georg.speidel.flexis.de
Hello @ all,
I'd like to write a plugin helping to work with SVN. As the future users
all have the subclipse-plugin already installed, I plan to use the package
"org.tigris.subversion.svnclientadapter.commandline" used by this plugin
to execute svn-commands.
To write my plugin, I installed subclipse 1.2.4 and added
"org.tigris.subversion.subclipse.core" to the Require-Bundle of the new
plugin's manifest.
Unfortunately, this not seems to be enough to use the commandline-package
via "import" in my new classes. The manifest of the subclipse-plugin
contains the path "/lib/svnClientAdapter.jar" in the "Bundle-ClassPath"
entry and the respective jar containing the class-files I need.
Has anybody a clue what more is required to use the commandline-package of
subclipse?
Thanks in advance!
Re: Use package from subclipse plugin [message #258551 is a reply to message #258531] |
Fri, 13 June 2008 14:00   |
It seems that another workaround is to import the Subclipse project into
your workspace.
I'm pretty much convinced that this is a bug in PDE, but different from
63576.
The symptoms seem to be that JARs contained within a plug-in in the
Target Platform are not detected by the PDE. I've been able to replicate
this problem with other bundles.
I've opened bug 237127 [1] to address this.
HTH,
Wayne
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=237127
On Fri, 2008-06-13 at 12:54 -0400, Wayne Beaton wrote:
> I can repeat the problem on Eclipse 3.3.1.1. What version are you using?
> I think this might be a regression of bug 63576. I will investigate it a
> little further.
> My working theory is that this is a problem with the PDE. It should work
> fine in runtime. To trick the PDE, try extracting the
> svnClientAdapter.jar from the plug-in and manually adding it to your
> Java build path (as an external JAR). At runtime, Equinox should find
> the JAR in the org.tigris.subversion.subclipse.core bundle.
> Wayne
> On Fri, 2008-06-13 at 16:26 +0000, Georg Speidel wrote:
> > Wayne Beaton wrote:
> > > Does the subclipse plug-in's manifest "export" the packages you need?
> > > i.e. are there Export-package entries?
> > Yes, the export-definitions are made
FUDForum. Page generated in 0.10293 seconds
