Home » Eclipse Projects » Eclipse Platform » how to change resource when its moved/renamed in 3.0
how to change resource when its moved/renamed in 3.0 [message #258068] Fri, 02 July 2004 22:01 Go to next message
Originally posted by: vadim.strizhevsky.remove.com
In 3.0 I have a resource type .foo in Java project (and also my nature as
well). I'd like to change the
resource when its moved or renamed. Similar to how JDT updates package
name of the .java file when
its moved. What's the best way to do this?
I thought using MoveParticipant would work, but after I dug deeper into
this, acording to
documentation participants can't modify the resource being moved. What are
my choices? Ideally I'd
like to own the whole Move/Rename refactoring of the .foo resources and
both move the resource and
modify it while doing that, but I couldn't find a way todo that.
Any help would be apreciated.
Vadim
Re: how to change resource when its moved/renamed in 3.0 [message #258359 is a reply to message #258068] Mon, 05 July 2004 06:25 Go to previous messageGo to next message
You can add an IResourceChangeListener (see
IWorkspace.addResourceChangeListener(IResourceChangeListener listener, int
eventMask)) that listen for PRE_BUILD events. During a PRE_BUILD
notification you can change resources.
Jerome
"Vadim Strizhevsky" <vadim@strizhevsky.remove.com> wrote in message
news:cc542j$lbm$1@eclipse.org...
> this, acording to
> Vadim
Re: how to change resource when its moved/renamed in 3.0 [message #258926 is a reply to message #258359] Tue, 06 July 2004 18:11 Go to previous messageGo to next message
Thanks, while it might be doable, its not exactly trivial, and feels in
the wrong place. You get notification about deletion and additon, not that
its moved. You have no way to abort it and say refactoring is bad (i.e no
way to checkPrecondition) etc...
I see in one of the older refactoring docs and plans notes about
pluggable Processors in addition to Participants, which is what I think I
need, but looks like that wasn't generalized into extensions in 3.0
timeframe :(
-Vadim
> Jerome
> > Hi,
> > this, acording to
> > Thanks,
> > Vadim
Re: how to change resource when its moved/renamed in 3.0 [message #259046 is a reply to message #258926] Wed, 07 July 2004 05:13 Go to previous message
Actually you get notification that it is moved. See the
IResourceDelta.MOVED_TO and MOVED_FROM flags.
For other issues you might want to enter feature requests.
Jerome
news:ccf83b$p7a$1@eclipse.org...
> timeframe :(
> -Vadim
int
> > Jerome
> > > Hi,
as
into
> > > this, acording to
are
and
> > > Thanks,
> > > Vadim
Previous Topic:How to run a plug-in project with template "Plug-in with an editor"
Next Topic:Synchronizing progress
Current Time: Wed Sep 10 22:02:16 EDT 2025
Powered by FUDForum. Page generated in 0.04527 seconds
