Home » Language IDEs » Java Development Tools (JDT) » Next/Previous Error in Editor?
Next/Previous Error in Editor? [message #257791] Mon, 15 December 2008 02:24 Go to next message
The Next/Previous Navigation commands in Editor window (uasually?) go the
next/previous error/warning. The Compiler Errors/Warnings settings
determine what gets flagged and how. The same errors/warnings are also
shows in Problems View, but here it is possible to further filter the
list.
Is it possible to filter this list in the Editor window? I would like to
see all errors and warnings in the Problems view but navigate only to
errors, ignoring warnings. This is so that I can see all the References to
Raw references in the Problems view but quickly jump to the next
unresolved identifier without having to press ctrl-. twenty times.
I guess I am looking for a "Next Error" command that I can bind ctrl-. to?
Thanks in advance.
Re: Next/Previous Error in Editor? [message #257795 is a reply to message #257791] Mon, 15 December 2008 04:01 Go to previous messageGo to next message
Hemal, there is a toolbar button that lets you select the annotation
types you want "Go to Next / Previous" to jump to. Look for a yellow
arrow pointing upwards / downwards.
-tom
> the next/previous error/warning. The Compiler Errors/Warnings settings
> list.
> to Raw references in the Problems view but quickly jump to the next
> to? Thanks in advance.
Re: Next/Previous Error in Editor? [message #257798 is a reply to message #257795] Mon, 15 December 2008 10:53 Go to previous message
Exactly what I needed. Thanks a ton.
> -tom
>> list.
Previous Topic:Source lookup path is not saved for debugging
Next Topic:jump to resource in navigator
Current Time: Fri Jul 25 08:32:23 EDT 2025
Powered by FUDForum. Page generated in 0.04630 seconds
