| JAVA_HOME for Any Build [message #257759] |
Fri, 02 July 2004 00:35  |
I have a small applet which I can run in eclipse (3.0) as a java applet
just fine. I wanted to see if I could create my own ant build file (shown
below), but it stops at the line:
<javac srcdir="${src}" destdir="${bin}" />
and the console window contains:
Buildfile: C:\Program Files\eclipse\workspace\test\build.xml
init:
compile:
[javac] Compiling 1 source file to
C:\Program Files\eclipse\workspace\test\bin
BUILD FAILED: C:\Program Files\eclipse\workspace\test\build.xml:16:
Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
Total time: 750 milliseconds
Can anyone help me figure out what I've done wrong?
Bobby Berns
<?xml version="1.0"?>
<project name="test" default="run" basedir=".">
<property name="src" value="." />
<property name="bin" value="bin" />
<property name="jar" value="jar" />
<property name="run" value="run" />
<target name="init">
<mkdir dir="${bin}" />
</target>
<target name="compile" depends="init">
<!-- Compile the java code -->
</target>
<target name="jar" depends="compile">
<jar jarfile="ctod.jar" includes="*.class" basedir="${bin}" />
</target>
<target name="run" depends="compile">
<!-- Run The Application -->
<java classpath="${build}" classname="ctod" />
</target>
</project>
| Re: JAVA_HOME for Any Build [message #257766 is a reply to message #257763] |
Fri, 02 July 2004 01:45  |
Sorry about the formatting...looked good on my screen :-(
Darins
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:cc2p6f$hsq$1@eclipse.org...
> This is a FAQ.
> You need a tools.jar on your Ant runtime classpath
> You have several choices (of which I list the three of the most common):
> start Eclipse using the -vm option to point to a JDK install and
Eclipse
> will automatically add a tools.jar to your Ant runtime classpath
> set your JAVA_HOME environment variable to point to a JDK install and
> Eclipse will automatically add a tools.jar to your Ant runtime classpath
> add a tools.jar from your favorite JDK install to your Ant runtime
> classpath either via the preferences (global setting) or as required on
the
> classpath tab of the
> individual Ant launch configuration.
> HTH
> Darins
> "Bobby Berns" <bobby@eagle-i.com> wrote in message
> news:cc2olo$h9u$1@eclipse.org...
(shown
> > init:
> > compile:
> > Thanks,
> > Bobby Berns
> > </target>
> > </target>
> > </target>
> > </target>
> > </project>
| Re: JAVA_HOME for Any Build [message #257769 is a reply to message #257766] |
Fri, 02 July 2004 01:23  |
Thanks Darin. Adding the -vm to the eclipse startup did it. I HAD set
JAVA_HOME to a jdk in my system environments variables, but that somehow
didn't do it.
I also found that If I set fork to yes in the javac, thus allowing ref to
external jdk handled it also.
> Darins
> > This is a FAQ.
> Eclipse
> the
> > HTH
> > Darins
> (shown
> > > Buildfile: C:Program Fileseclipseworkspacetestbuild.xml
> > > init:
> > > compile:
> > > C:Program Fileseclipseworkspacetestbin
> > > BUILD FAILED: C:Program Fileseclipseworkspacetestbuild.xml:16:
> > > Thanks,
> > > Bobby Berns
> > > </target>
> > > </target>
> > > </target>
> > > </target>
> > > </project>
FUDForum. Page generated in 0.06581 seconds
