Home » Archived » BIRT » Best Way to Hide and Disable a Chart/Table?
Best Way to Hide and Disable a Chart/Table? [message #257695] Tue, 09 October 2007 11:53 Go to next message
I have a report consisting of 6 charts and 6 tables. Only one chart and
table combination is visible at a time depending on the parameters the
user selects. I am able to use the Visibility to functionality to hide
elements. But the problem is that even though the element is hidden, the
query still executes. So I'm having 12 queries execute when only 2 would
suffice.
I tried dropping the chart/table in the Visibility expression but it
still executes the query
if(params["OrderGroup"] == "ALLORDERS" && params["MeasuredBy"] =="QUANTITY")
false;
else
reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "NewChart2").drop();
true;
I then tried putting the drop statement in the beforeFactory event of
the report and it worked. Is that the best place to "drop" elements/to
do what I want to do?
Re: Best Way to Hide and Disable a Chart/Table? [message #257856 is a reply to message #257695] Wed, 10 October 2007 16:03 Go to previous message
Originally posted by: jasonweathersby.alltel.net
beforeFactory is the best place.
Jason
Raishad wrote:
> suffice.
> =="QUANTITY")
> false;
> else
> true;
> Thanks
Previous Topic:max rows within crosstab
Next Topic:lower - upper case in column names are a problem
Current Time: Sat Nov 22 03:00:36 EST 2025
Powered by FUDForum. Page generated in 0.03928 seconds
