Home » Archived » BIRT » Scripted Data Set ReferenceError
Scripted Data Set ReferenceError [message #257420] Mon, 08 October 2007 00:26 Go to next message
I'm getting the following error message:
WARNING: A BIRT exception occurred: Error evaluating Javascript
expression. Script engine error: ReferenceError: "ReportController" is
not defined. (DataSet[set_KRIBU].__bm_beforeOpen#15)
Where do I need to put the containing jar file to have it available to
the script (I'm running BIRT 2.2.0)?
I am running BIRT on a Tomcat webserver, and the BIRT_HOME location is
"Tomcat 5.5.23/webapps/reporting/WEB-INF/platform".
I've tried putting the jar file in these locations, but none of them
have worked:
/platform/lib
/platform/scriptlib
/platform/plugins
/WEB-INF/lib
/WEB-INF/scriptlib
Thanks in advance for your help.
-Ian Tyrrell
Re: Scripted Data Set ReferenceError [message #257517 is a reply to message #257420] Mon, 08 October 2007 11:43 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Ian,
either of the WEB-INF directories should have worked using the report
viewer. Are you writing your own servlet or using the viewer. If you
are using the Viewer you should not have to set BIRT_HOME.
Jason
Ian Tyrrell wrote:
> have worked:
> /platform/lib
> /platform/scriptlib
> /platform/plugins
> /WEB-INF/lib
> /WEB-INF/scriptlib
> -Ian Tyrrell
Re: Scripted Data Set ReferenceError [message #257592 is a reply to message #257517] Mon, 08 October 2007 18:19 Go to previous messageGo to next message
Hi Jason,
It's our own servlet (I think, I'm not real sure - as far as I can tell,
it's just BIRT stuff in there) - I am trying to use it to render the
reports to a file at the moment, using it for viewing online works fine.
I have had to set the BIRT_HOME as an environment setting.
What would I need to do to get it working in my own servlet?
Ian
Jason Weathersby wrote:
> Ian,
> Jason
> Ian Tyrrell wrote:
>> Hi,
>> have worked:
>> /platform/lib
>> /platform/scriptlib
>> /platform/plugins
>> /WEB-INF/lib
>> /WEB-INF/scriptlib
>> -Ian Tyrrell
Re: Scripted Data Set ReferenceError [message #257596 is a reply to message #257592] Mon, 08 October 2007 20:18 Go to previous message
OK,
for the minute I seem to have it working (I set the appContext's
classloader to the classloader used by the java file I want), and that
seems to be working now.
Thanks.
-Ian Tyrrell
Ian Tyrrell wrote:
> Hi Jason,
> Ian
>> Ian,
>> Jason
>> Ian Tyrrell wrote:
>>> Hi,
>>> is not defined. (DataSet[set_KRIBU].__bm_beforeOpen#15)
>>> to the script (I'm running BIRT 2.2.0)?
>>> is "Tomcat 5.5.23/webapps/reporting/WEB-INF/platform".
>>> have worked:
>>> /platform/lib
>>> /platform/scriptlib
>>> /platform/plugins
>>> /WEB-INF/lib
>>> /WEB-INF/scriptlib
>>> -Ian Tyrrell
Previous Topic:change color of a single bar in a chart series
Next Topic:BIRT 2.2.1- Functionality removed from COUNTDISTINCT/COUNT?
Current Time: Sun Jul 27 16:13:15 EDT 2025
Powered by FUDForum. Page generated in 0.04977 seconds
