Home » Eclipse Projects » GEF » Should getModelSourceConnections() be implemented in nodes's EditParts or in their container's EditP
Should getModelSourceConnections() be implemented in nodes's EditParts or in their container's EditP [message #25746] Tue, 08 October 2002 11:41 Go to next message
I am trying to clarify a point with connections:
according to GEF overview, "connections are similar to children. There are
methods for source and target connections that parallel the ones for
creating children above [...]"
In that case, should I implement getModelSourceConnection() and
getModelTargetConnection() method in the EditPart associated to my nodes, or
into the EditPart associated to my node's container model?
I guess that the implementation should be at the node's EditPart level, but
not quite sure...
please let me know your own guess...
Alex.
Re: Should getModelSourceConnections() be implemented in nodes's EditParts or in their container's E [message #25777 is a reply to message #25746] Wed, 09 October 2002 03:06 Go to previous messageGo to next message
> not quite sure...
I have implemented it in my node EditPart and it works fine.
But I have a problem when my model changes, e.g. I delete
(ConnectionEditPolicy) or reconnect (GraphicalNodeEditPolicy) a
Connection. My Graph is never updated. I'm not quite sure which
refresh Methode to call on which EditPart.
Calling refreshSourceConnections() and refreshTargetConnections() on
my node EditPart dosen't work properly.
Volker
Re: Should getModelSourceConnections() be implemented in nodes's EditParts or in their container's E [message #26187 is a reply to message #25746] Wed, 09 October 2002 10:26 Go to previous messageGo to next message
or
In GEF, Source and Target connections are a structural feature of your Node
**EditParts**. This doesn't necessarily mean that the same is true in your
model, although it often is. Some applications might store all of the
connection at the diagram, and the Nodes don't know about the connections.
But, it is easier to build connections from the node editparts because of
ordering requirements. How can you build the Connection's figure and attach
it to the node's Anchor if the Node's figure doesn't exist yet? Worrying
about this type of ordering is difficult, since you have to consider
undo/redo, and other possible ways in which nodes and connection come and
go.
In applications where connections are stored in the diagram (and the node
model does not have a reference to them), then getModelSourceConnections()
is implemented by first navigating to the diagram's EditPart, and then
finding the connections for that node.
but
> not quite sure...
> Alex.
Re: Should getModelSourceConnections() be implemented in nodes's EditParts or in their container's E [message #26590 is a reply to message #26187] Wed, 09 October 2002 11:23 Go to previous messageGo to next message
Thank you very much for this detailled answer.
Let me begin with get*ModelConnections at node's EditPart, as you
recommend...
Alex.
Re: Should getModelSourceConnections() be implemented in nodes's EditParts or in their container's E [message #30224 is a reply to message #25777] Sun, 13 October 2002 12:27 Go to previous message
Originally posted by: g.wagenknecht.planet-wagenknecht.de
Hi!
"Volker Krebs" <volker.krebs@abas.de> schrieb im Newsbeitrag
news:1034147165.890939@miraculix...
Mhm, did you try refreshing the parent? I'm not sure but in some cases it is
necessary. Anyway, I implemeted a mechanisme on my model. The Edit Parts
just listens to their model object. This allows me to work on my model and
delegate necessary change events to other model objects. So I don't have to
take care about which edit part to refresh although you should know it
because I designed the application ;)
Cu, Gunnar
Previous Topic:Add other SWT controls in the Palette?
Next Topic:Control how an Edit Part move in GEF
Current Time: Fri Sep 19 09:40:18 EDT 2025
Powered by FUDForum. Page generated in 0.04063 seconds
