Home » Eclipse Projects » Eclipse Platform » eclipse 3.0 not starting
eclipse 3.0 not starting [message #257319] Wed, 30 June 2004 22:04 Go to next message
Originally posted by: llowejr.usa.net
I just downloaded 'eclipse-SDK-3.0-win32.zip' and unzipped it to the root
of my c drive and I can't get it running. I have never used eclipse
before and I am new to java. Below is the log file. Please help.
Larry
!SESSION Jun 30, 2004 22:04:45.190
eclipse.buildId=I200406251208
java.version=1.3.1_01
!ENTRY org.eclipse.osgi Jun 30, 2004 22:04:45.200
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
at
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
at
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!ENTRY org.eclipse.osgi Jun 30, 2004 22:04:45.311
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:552)
at
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
at
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:655)
at
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:219)
at
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:177)
at
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
at
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:266)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
at
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
at
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
at
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
at
!ENTRY org.eclipse.osgi Jun 30, 2004 22:04:45.341
!MESSAGE Bundle
initial@reference :file:c:/eclipse-SDK-3.0-win32/eclipse/plugins/org.eclipse.c ore.runtime_3.0.0/
[1] was not resolved.
Re: eclipse 3.0 not starting [message #257328 is a reply to message #257319] Wed, 30 June 2004 23:24 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
Eclipse 3.0 requires a JDK 1.4. You are running with a 1.3.1_01
PaScaL
> Thanks
> Larry
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
Re: eclipse 3.0 not starting [message #257426 is a reply to message #257328] Thu, 01 July 2004 07:41 Go to previous message
Thanks Pascal, I must look at that for 2 hours and just did not see it. I
have Oracle 9i installed locally and it uses the older java version. I
changed my path and fixed eclipse.
Thanks again,
Larry
> PaScaL
> > Thanks
> > Larry
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > !STACK 1
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > !MESSAGE Bundle
Previous Topic:[Question] inner brackets-highlight / Scoping
Next Topic:version 2.1.3 and 3.0 on one system?
Current Time: Wed Jul 23 17:31:44 EDT 2025
Powered by FUDForum. Page generated in 0.04062 seconds
