Home » Eclipse Projects » Eclipse Platform » error while starting Eclipse as runtime-workbench
error while starting Eclipse as runtime-workbench [message #257241] Wed, 30 June 2004 16:21 Go to next message
Originally posted by: franz.hoyer.franzhoyer.de
When I try to launch Eclipse inside Eclipse for a debug session I get the
following error:
I try to run it on a windows xp machine.
!SESSION Jun 30, 2004
22:16:34.234 ---------------------------------------------
eclipse.buildId=unknown
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -application org.eclipse.ui.ide.workbench
!ENTRY org.eclipse.osgi Jun 30, 2004 22:16:34.250
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: no swt-carbon-3062 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.graphics.Device.init(Device.java:564)
at org.eclipse.swt.widgets.Display.init(Display.java:1780)
at org.eclipse.swt.graphics.Device.<init>(Device.java:100)
at org.eclipse.swt.widgets.Display.<init>(Display.java:355)
at org.eclipse.swt.widgets.Display.<init>(Display.java:351)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:278)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:153)
at
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java
:122)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:72)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Re: error while starting Eclipse as runtime-workbench [message #257250 is a reply to message #257241] Wed, 30 June 2004 17:21 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
It looks like you do not have the correct version of swt.jar since you
are on a XP platform, but the library being loaded is "carbon" (macos).
Make sure that you have the proper version of SWT.
PaScaL
> following error:
> !STACK 1
> at
> :122)
> at
> java:335)
> at
> at
Re: error while starting Eclipse as runtime-workbench [message #257261 is a reply to message #257250] Wed, 30 June 2004 17:48 Go to previous messageGo to next message
well I have all different kinds of swt.jar for all different platforms. How
can i tell eclipse to use the one for win32 ? I thought the startup
parameter points eclipse to the right swt ?
I start with -os win32 -ws win32 -arch x86 -nl de_DE
where or how can i tell eclipse to load the one for win32 and not the carbon
"Pascal Rapicault" <pascal@ibm.canada> schrieb im Newsbeitrag
news:cbvarj$trq$1@eclipse.org...
> PaScaL
the
> > following error:
> > !STACK 1
> > at
> > :122)
> > at
> > at
> > java:335)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: error while starting Eclipse as runtime-workbench [message #257265 is a reply to message #257261] Wed, 30 June 2004 17:59 Go to previous message
just found a way to solve it, I am not sure if it is the best way to do it
but it works.
I copied the right swt.jar (the one for win32) into the org.eclipse.swt.bin
directory. It seems that puts the swt.jar in the classpath and now eclipse
uses at startup that library.
"Franz Hoyer" <franz.hoyer@franzhoyer.de> schrieb im Newsbeitrag
news:cbvceb$1ga$1@eclipse.org...
How
carbon
> > PaScaL
> the
> > > following error:
> > > !STACK 1
java.library.path
> > > at
> > > at
> > > :122)
> > > at
> > > at
> > > java:335)
> > > at
> > > at
Previous Topic:Startup speed for RCP apps versus stand-alone JFace
Next Topic:which api is usefull for retriving the the project details from with the plugin?
Current Time: Wed Sep 03 10:36:43 EDT 2025
Powered by FUDForum. Page generated in 0.07712 seconds
