Home » Eclipse Projects » Eclipse Platform » Undo/Redo in PropertySheet
Undo/Redo in PropertySheet [message #257038] Wed, 30 June 2004 06:20 Go to next message
Originally posted by: alex.xxxxxxxx.xxxxx
Hi!
I have a GEF Editor and a PropertySheet. Is there a way to enable
undo/redo actions in the PropertySheet? Or should I create editor commands
and execute them each time a property was changed?
thank you in advance
Re: Undo/Redo in PropertySheet [message #257130 is a reply to message #257038] Wed, 30 June 2004 10:41 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
In GEF, undo/redo are done through commands. The default GEF property
sheet entry will create the default set/reset commands that are
necessary for undo/redo using the command stack to work.
The property sheet itself has no concept of undo/redo because that
depends on the editor. Each editor has a different way. For example text
editors do it by keystrokes. GEF does it by commands and its command stack.
Thanks, Rich Kulp
Previous Topic:Free UML diagramming / code generating plugin?
Next Topic:stopping Console View from popping up
Current Time: Sun Jul 27 15:31:53 EDT 2025
Powered by FUDForum. Page generated in 0.03917 seconds
