Home » Language IDEs » Java Development Tools (JDT) » replacing a token with the current date (plus time and/or version)?
replacing a token with the current date (plus time and/or version)? [message #256891] Mon, 13 October 2008 08:16 Go to next message
I am seeking an way to change some placeholder (string) in my source
code to the value of the data + time when the source code was compiled,
such that the running application can later emit its compilation time
(and ideally also the time and/or some running compilation number) in
its help => about dialog.
What's the cheapest (or most elegant) way to achieve this using eclipse
(or its built-in ant)?
Michael
Re: replacing a token with the current date (plus time and/or version)? [message #256895 is a reply to message #256891] Mon, 13 October 2008 08:53 Go to previous messageGo to next message
Eclipse's compiler has no capability for doing something like this, but
you could write a small Ant script that did the replace before
compilation happens, then add that Ant script as a custom builder to
your project. See
http://bewarethepenguin.blogspot.com/2008/08/customizing-bui lds-for-your-eclipse.html
(in your case you'll want to make sure your custom builder runs BEFORE
the Java Builder).
Hope this helps,
Eric
Re: replacing a token with the current date (plus time and/or version)? [message #256931 is a reply to message #256895] Wed, 15 October 2008 04:43 Go to previous messageGo to next message
> but you could write a small Ant script that did the replace before
> your project. See
> the Java Builder).
> Hope this helps,
> Eric
Thanks Eric,
that helped. I defined a build.xml containing an ant task that is
executed as part of the normal build.
One last question, tough. I am not exactly an ant guru and I find my
solution a bit trivial or, let say, not so elegant. What my ant-task
does is, to take a file "foo.template" which contains a token/substring
@timestamp@ and at each build it copies that file over to a file
"foo.java" while replacing that token with the current time.
Is there a solution to does something like that "inplace" - I mean,
without needing an additional ".template" file, but rather able to live
with the .java file only?
Some mechanism, that identifies an old date and timestamp within a
string (which might also be marked somehow, e.g. with a comment
preceeding that string declaration or such to easier identify it) and
replaces that with the current time?
Just curious to learn some new trick...
Michael
Re: replacing a token with the current date (plus time and/or version)? [message #256936 is a reply to message #256931] Wed, 15 October 2008 09:20 Go to previous message
>> your project. See
>> the Java Builder).
>> Hope this helps,
>> Eric
> Thanks Eric,
I can't think of any way to do that with built-in Ant tasks (but I'm
rusty, it has been a few years since I was doing much Ant writing); you
might want to ask on the Ant forums.
I do know that custom Ant tasks are pretty easy to write and this sounds
like a good candidate for that. Here's some links to get you started:
http://ant.apache.org/ant_task_guidelines.html
http://ant.apache.org/manual/develop.html
Eric
Previous Topic:impossible to refactor/reference/etc toString() method
Next Topic:Converting a project to use Ant
Current Time: Wed Nov 05 21:04:34 EST 2025
Powered by FUDForum. Page generated in 0.03913 seconds
