Home » Archived » BIRT » pdf files damaged when viewing
pdf files damaged when viewing [message #256741] Tue, 02 October 2007 10:28 Go to next message
Originally posted by: murchmeister.gmail.com
When I view a BIRT report in pdf format I see a file damaged pop-up from
Adobe.
WebViewerExample/frameset?__report=Report/REPORT.rptdesign&a mp;__format=pdf&__overwrite=false
The log file is below - the html reports run ok.
SEVERE: An error happened while running the report. Cause:
at
org.eclipse.birt.report.engine.layout.pdf.cache.TableAreaLay out$Row. <init>(TableAreaLayout.java:1158)
at
org.eclipse.birt.report.engine.layout.pdf.cache.TableAreaLay out$Row. <init>(TableAreaLayout.java:1138)
at
org.eclipse.birt.report.engine.layout.pdf.cache.TableAreaLay out$Row. <init>(TableAreaLayout.java:1144)
at
org.eclipse.birt.report.engine.layout.pdf.cache.TableAreaLay out.addRow(TableAreaLayout.java:720)
at
org.eclipse.birt.report.engine.layout.pdf.PDFTableLM.addRow( PDFTableLM.java:777)
at
org.eclipse.birt.report.engine.layout.pdf.PDFRowLM.submitRoo t(PDFRowLM.java:125)
at
org.eclipse.birt.report.engine.layout.pdf.PDFInlineStackingL M.autoPageBreak(PDFInlineStackingLM.java:68)
at
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .autoPageBreak(PDFBlockStackingLM.java:560)
at
at
at
at
org.eclipse.birt.report.engine.layout.pdf.PDFInlineStackingL M.autoPageBreak(PDFInlineStackingLM.java:65)
at
at
at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.endPage( PDFPageLM.java:249)
at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layout(P DFPageLM.java:217)
at
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layoutReport(PDFReportLayoutEngine.java:64)
at
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layout(PDFReportLayoutEngine.java:87)
at
org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange Render.render(RenderTask.java:501)
at
org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.java:254)
at
org.eclipse.birt.report.service.ReportEngineService.renderRe port(Unknown
Source)
at
org.eclipse.birt.report.service.BirtViewerReportService.rend erReport(Unknown
Source)
at
org.eclipse.birt.report.service.actionhandler.BirtRenderRepo rtActionHandler.__execute(Unknown
Source)
at
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source)
at
org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.doService(Unknown
Source)
at
org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.service(Unknown
Source)
at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(Unknow n Source)
at
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:230)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:175)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:104)
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:261)
at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:844)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:581)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
Re: pdf files damaged when viewing [message #256771 is a reply to message #256741] Tue, 02 October 2007 12:17 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Murch,
What version of BIRT are you using?
Jason
Murch wrote:
> Adobe.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: pdf files damaged when viewing [message #256781 is a reply to message #256771] Tue, 02 October 2007 12:38 Go to previous messageGo to next message
2.2.0 running a webserver using Apache Tomcat
Re: pdf files damaged when viewing [message #256786 is a reply to message #256781] Tue, 02 October 2007 13:22 Go to previous message
Murch,
can you try
WebViewerExample/frameset?__report=Report/REPORT.rptdesign&a mp;__format=pdf&__overwrite=true
Previous Topic:ModuleHandle listAllImages returns emtpy list
Next Topic:Dynamic Markers on the Graph
Current Time: Fri Jul 18 17:53:40 EDT 2025
Powered by FUDForum. Page generated in 0.03929 seconds
