Home » Newcomers » Newcomers » eclipse crashes
eclipse crashes [message #256713] Mon, 19 May 2008 13:38 Go to next message
Originally posted by: jamescchandler.nsgmnsail.com
I'm running eclipse 3.3.1 on Solaris 8. It starts up fine. However
if I click on a file in the Package Explorer it crashes with the
following error:
ld.so.1: /h/users/user/eclipse/eclipse: fatal: relocation error: file
/h/users/user/eclipse/configuration/org.eclipse.osgi/bundles /96/1/.cp/libswt-gnome-gtk-3349.so:
symbol gnome_icon_theme_new: referenced symbol not found.\
I've googled the world over and cannot seem to find the cure to my ill.
Thanks for your help,
Jim
Re: eclipse crashes [message #256761 is a reply to message #256713] Tue, 20 May 2008 05:55 Go to previous messageGo to next message
Hi Jim,
I found the following related threads :
http://linux.derkeiler.com/Mailing-Lists/SuSE/2007-09/msg014 38.html
http://lists.alioth.debian.org/pipermail/pkg-evolution-maint ainers/2007-September/003021.html
I found another thread in French on openSolaris newsgroup :
http://opensolaris.org/jive/thread.jspa?threadID=55149&t start=75
The problems seems more related to gnome and solaris rather than Eclipse, so I suggest you to ask on their newsgroups.
I forwarded too this thread to swt newsgroup, may be someone could help you to solve your problem.
Mariot
> following error:
> Jim
Re: eclipse crashes [message #257564 is a reply to message #256713] Tue, 03 June 2008 08:58 Go to previous messageGo to next message
I actually discovered my problem quite by accident. It was a little bit
of confusion on my part. I actually had two versions of eclipse running
on my machine for Solaris. One was 3.3.2 and the other was 3.3.1.1. I
was running 3.3.2 and the one for Solaris 8 was 3.3.1.1, once I had
figured this out and started using the correct one, my problem
disappeared. Just in case someone else has the same problem.
Jim
> following error:
> Jim
Re: eclipse crashes [message #675042 is a reply to message #256713] Mon, 30 May 2011 02:36 Go to previous message
I have the same problem and I have googled the whole world over as well. Did you ever find a solution? I followed all the replies but none seemd to help.
Edit: to reply I had to join and now I have joined I can see that you had the answer. I shall go and torment the admin till he mends it (or gives me the su password).
[Updated on: Mon, 30 May 2011 02:38] by Moderator
Previous Topic:Trouble with autocomplete and bracket insertion
Next Topic:backup workspace project work in progress
Current Time: Fri Sep 19 07:50:08 EDT 2025
Powered by FUDForum. Page generated in 0.12802 seconds
