Page Break in Birt 2.2 [message #252743] |
Thu, 16 August 2007 10:05  |
Originally posted by: synus.synus.ch
Hello
I installed birt 2.2. on our webserver. It works so far, except of
customized page breaks.
There is a table with 4 groups and I want birt to insert a page break if
there is not enough space to print the whole second group on the current
page.
I tried to assign "Page Break - avoid" to the second group but it didn't
work.
I also tried to assign "Page Break - avoid" to every single item in group 2
including groups 3, 4. Also didn't work.
I hope you can help me.
Yours sincerely,
synus
Re: Group Header Page Break in Birt 2.2 [message #258671 is a reply to message #257747] |
Thu, 18 October 2007 03:23   |
Originally posted by: vivek.madurai.orangescape.com
paal,
thanks a lot.
regards
vivek
Paal Espen Reinertsen wrote:
> Upgrading to 2.2.1 solved my problems.
> "Paal Espen Reinertsen" <pal.espen.reinertsen@gmail.com> wrote in message
> news:fdfp27$65i$1@build.eclipse.org...
>>Hi,
>>Sounds like you have a similar problem as I have.
>>I have not solved it yet but according to bug 196186 this is solved in
>>2.2.1 of BIRT:
>>https://bugs.eclipse.org/bugs/show_bug.cgi?id=196186
>>Let me know if you manage to solve the problem.
>>Regards,
>>Pål Espen
>>"Vivekanandan Madurai" <vivek.madurai@orangescape.com> wrote in message
>>news:fdfj82$f0h$1@build.eclipse.org...
>>>Hi,
>>>I installed the major release, BIRT 2.2. It works so far, except the
>>>I have a group in which i want to avoid the page break if there is not
>>>enough space to print the whole group in a single page.
>>>I tried to assign "Page Break - avoid" to the that group,but it didn't
>>>work.
>>>If somebody is aware of this issue,kindly help me in resolving this.
>>>Yours sincerely,
>>>vivek
Re: Group Header Page Break in Birt 2.2 [message #258985 is a reply to message #257747] |
Mon, 22 October 2007 09:19   |
My problem is solved by doing some work around via scripting in BIRT 2.2
Release itself,
http://wiki.eclipse.org/GroupSeparator_(BIRT)
regards
vivek
>>Hi,
>>2.2.1 of BIRT:
>>Regards,
>>Pål Espen
>>>Hi,
>>>work.
>>>Yours sincerely,
>>>vivek
Re: Group Header Page Break in Birt 2.2 [message #259168 is a reply to message #258985] |
Tue, 23 October 2007 13:07  |
Vivekanandan,
That link did not seem to work.
Scott Rosenbaum
> 2.2 Release itself,
> regards
> vivek
>> message news:fdfp27$65i$1@build.eclipse.org...
>>> Hi,
>>> in
>>> 2.2.1 of BIRT:
>>> Regards,
>>> Pål Espen
>>> message news:fdfj82$f0h$1@build.eclipse.org...
>>>> Hi,
>>>> the customized page breaks.
>>>> not enough space to print the whole group in a single page.
>>>> didn't
>>>> work.
>>>> this.
>>>> Yours sincerely,
>>>> vivek
FUDForum. Page generated in 0.04923 seconds
