Home » Newcomers » Newcomers » Generate Eclipse makefiles from command line
Generate Eclipse makefiles from command line [message #256366] Wed, 14 May 2008 15:23 Go to next message
Originally posted by: register.me.now.please.gmail.com
I would like to be able to generate Eclipse makefiles from Eclipse project
file from the command line without running the Eclipse GUI.
Does anyone know if this is possible?
Jeff
Re: Generate Eclipse makefiles from command line [message #256389 is a reply to message #256366] Wed, 14 May 2008 15:58 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
If you mean for building java or plugins, then yes, headless Eclipse is
possible. See http://www.google.com/search?q=headless+pde+build, or use
the Eclipse Help system within Eclipse for starting docs.
There's also http://help.eclipse.org, if you like your doc online. :)
Nick
> project file from the command line without running the Eclipse GUI.
> Thanks
> Jeff
Re: Generate Eclipse makefiles from command line [message #256393 is a reply to message #256366] Wed, 14 May 2008 17:16 Go to previous message
> Thanks
> Jeff
Are you talking about CDT makefiles? If so, this is not possible.
However, CDT does create makefiles (from within the UI) that can then be
used externally.
HTH
Derek
Previous Topic:how to compile and run outside of eclipse
Next Topic:Eclipse failing to start
Current Time: Fri Nov 21 09:19:21 EST 2025
Powered by FUDForum. Page generated in 0.06096 seconds
