Home » Archived » BIRT » BIRT Chart with scripted data source invokes the method twice
BIRT Chart with scripted data source invokes the method twice [message #255894] Thu, 20 September 2007 23:44 Go to next message
Originally posted by: vencat.b.gmail.com
Hi david/jason,
I have a report with chart designed using scripted data source (POJO). For
some strange reason, its executing the pojo method twice and this results to
querying database twice.
I'm using BIRT 2.1.3 and this is line chart.
Please let me know.
Re: BIRT Chart with scripted data source invokes the method twice [message #255920 is a reply to message #255894] Fri, 21 September 2007 12:20 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Venc,
I believe this is a known issue. Should be corrected soon. One work
around might be to load a hash with your result sets and then check the
hash the second time the script runs.
Jason
venc wrote:
> Hi david/jason,
> Please let me know.
> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #255931 is a reply to message #255920] Fri, 21 September 2007 14:22 Go to previous messageGo to next message
Hi jason,
Thanks for quick response. Is there bugzilla entry for this? Also will
there be another patch release to 2.1.3. This seems a critical and
fundamental performance issue. I'm not sure if this is with other data
sources as well.
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:fd0qrh$7lu$1@build.eclipse.org...
> Venc,
> Jason
> venc wrote:
>> Hi david/jason,
>> For some strange reason, its executing the pojo method twice and this
>> results to querying database twice.
>> Please let me know.
>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256025 is a reply to message #255931] Mon, 24 September 2007 12:03 Go to previous messageGo to next message
Venc,
Look at this entry.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=151427
Jason
venc wrote:
> Hi jason,
> sources as well.
>> Venc,
>> Jason
>> venc wrote:
>>> Hi david/jason,
>>> Please let me know.
>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256083 is a reply to message #256025] Mon, 24 September 2007 19:04 Go to previous messageGo to next message
Thanks jason for looking into the details of this. Is there any chance this
bug fix be back-patched to 2.1.3 release.
Thank you.
news:fd8mvj$rfr$1@build.eclipse.org...
> Venc,
> Look at this entry.
> Jason
> venc wrote:
>> Hi jason,
>> sources as well.
>>> Venc,
>>> Jason
>>> venc wrote:
>>>> Hi david/jason,
>>>> (POJO). For some strange reason, its executing the pojo method twice
>>>> and this results to querying database twice.
>>>> Please let me know.
>>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256126 is a reply to message #256083] Tue, 25 September 2007 11:09 Go to previous messageGo to next message
Venc,
I will check into it, but I do not believe there are any plans to do
that currently.
Jason
> Thank you.
>> Venc,
>> Look at this entry.
>> Jason
>> venc wrote:
>>> Hi jason,
>>> sources as well.
>>>> Venc,
>>>> Jason
>>>> venc wrote:
>>>>> Hi david/jason,
>>>>> Please let me know.
>>>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256149 is a reply to message #256126] Tue, 25 September 2007 14:20 Go to previous messageGo to next message
Please do and many thanks. We have multiple charts in a dashboard and you
can imagine how bad this would be because of each chart query being executed
twice.
news:fdb87m$761$1@build.eclipse.org...
> Venc,
> I will check into it, but I do not believe there are any plans to do that
> currently.
> Jason
>> this bug fix be back-patched to 2.1.3 release.
>> Thank you.
>>> Venc,
>>> Look at this entry.
>>> Jason
>>> venc wrote:
>>>> Hi jason,
>>>> will there be another patch release to 2.1.3. This seems a critical and
>>>> sources as well.
>>>>> Venc,
>>>>> the hash the second time the script runs.
>>>>> Jason
>>>>> venc wrote:
>>>>>> Hi david/jason,
>>>>>> Please let me know.
>>>>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256166 is a reply to message #256149] Tue, 25 September 2007 16:04 Go to previous messageGo to next message
Venc,
Can you not use a hash as a work around?
Jason
> twice.
>> Venc,
>> currently.
>> Jason
>>> Thank you.
>>>> Venc,
>>>> Look at this entry.
>>>> Jason
>>>> venc wrote:
>>>>> Hi jason,
>>>>> sources as well.
>>>>>> Venc,
>>>>>> Jason
>>>>>> venc wrote:
>>>>>>> Hi david/jason,
>>>>>>> Please let me know.
>>>>>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256183 is a reply to message #256166] Tue, 25 September 2007 19:11 Go to previous messageGo to next message
Jason,
Can you elaborate further on this approach. Any workaround is good for me.
news:fdbpgf$9eb$1@build.eclipse.org...
> Venc,
> Jason
>> executed twice.
>>> Venc,
>>> that currently.
>>> Jason
>>>> Thank you.
>>>>> Venc,
>>>>> Look at this entry.
>>>>> Jason
>>>>> venc wrote:
>>>>>> Hi jason,
>>>>>> and fundamental performance issue. I'm not sure if this is with other
>>>>>> data sources as well.
>>>>>>> Venc,
>>>>>>> work around might be to load a hash with your result sets and then
>>>>>>> check the hash the second time the script runs.
>>>>>>> Jason
>>>>>>> venc wrote:
>>>>>>>> Hi david/jason,
>>>>>>>> twice and this results to querying database twice.
>>>>>>>> Please let me know.
>>>>>>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256272 is a reply to message #256183] Wed, 26 September 2007 10:09 Go to previous messageGo to next message
Venc,
I am not certain how your SDS is working, but if you are calling an
external POJO to get the rows you can set a global variable in BIRT
script the first time you run the SDS. At the same time in Script
create a Java HashMap to hold your rows. The second time through read
the HashMap for rowdata instead of your external system. This will
still be a performance hit, but should not be as bad.
Jason
venc wrote:
> Jason,
>> Venc,
>> Jason
>>> executed twice.
>>>> Venc,
>>>> that currently.
>>>> Jason
>>>>> Thank you.
>>>>>> Venc,
>>>>>> Look at this entry.
>>>>>> Jason
>>>>>> venc wrote:
>>>>>>> Hi jason,
>>>>>>>> Venc,
>>>>>>>> Jason
>>>>>>>> venc wrote:
>>>>>>>>> Hi david/jason,
>>>>>>>>> Please let me know.
>>>>>>>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256517 is a reply to message #256272] Fri, 28 September 2007 10:06 Go to previous messageGo to next message
Thanks jason. I have to think about how this would work. I tried few things
using parameter to ignore either the first or second call but did not work
for me. I wish this was fixed. I chose BIRT over crystal and i hope this
works out well for me. Please check with PMC and let me know if this could
be fixed for 2.1.3.
Even difference in rendering times between using /run and /frameset is
something i could not understand. /frameset downloads about 15-20 JS files
and i did not experience these pagination issues when using crystal JRC.
news:fddp1g$gi6$1@build.eclipse.org...
> Venc,
> external POJO to get the rows you can set a global variable in BIRT script
> the first time you run the SDS. At the same time in Script create a Java
> HashMap to hold your rows. The second time through read the HashMap for
> rowdata instead of your external system. This will still be a performance
> Jason
> venc wrote:
>> Jason,
>> me.
>>> Venc,
>>> Jason
>>>> you can imagine how bad this would be because of each chart query being
>>>> executed twice.
>>>>> Venc,
>>>>> that currently.
>>>>> Jason
>>>>>> chance this bug fix be back-patched to 2.1.3 release.
>>>>>> Thank you.
>>>>>>> Venc,
>>>>>>> Look at this entry.
>>>>>>> Jason
>>>>>>> venc wrote:
>>>>>>>> Hi jason,
>>>>>>>> Also will there be another patch release to 2.1.3. This seems a
>>>>>>>> critical and fundamental performance issue. I'm not sure if this is
>>>>>>>> with other data sources as well.
>>>>>>>>> Venc,
>>>>>>>>> Jason
>>>>>>>>> venc wrote:
>>>>>>>>>> Hi david/jason,
>>>>>>>>>> Please let me know.
>>>>>>>>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256841 is a reply to message #256517] Tue, 02 October 2007 20:49 Go to previous messageGo to next message
hi jason,
I noticed that this problem exists only using /run and not /frameset.
/run POJO method gets invoked twice
/frameset POJO method invoked only once.
I'm thinking write a servlet which simulates /frameset to display on
dashboard with no BIRT Toolbar. Would that work and how should i? I think
RunAndRender task has this issue. Thanks
"venc" <vencat.b@gmail.com> wrote in message
news:fdj1ng$v9t$1@build.eclipse.org...
> things using parameter to ignore either the first or second call but did
> not work for me. I wish this was fixed. I chose BIRT over crystal and i
> hope this works out well for me. Please check with PMC and let me know if
> this could be fixed for 2.1.3.
>> Venc,
>> script the first time you run the SDS. At the same time in Script create
>> a Java HashMap to hold your rows. The second time through read the
>> HashMap for rowdata instead of your external system. This will still be
>> Jason
>> venc wrote:
>>> Jason,
>>> me.
>>>> Venc,
>>>> Jason
>>>>> being executed twice.
>>>>>> Venc,
>>>>>> that currently.
>>>>>> Jason
>>>>>>> Thank you.
>>>>>>>> Venc,
>>>>>>>> Look at this entry.
>>>>>>>> Jason
>>>>>>>> venc wrote:
>>>>>>>>> Hi jason,
>>>>>>>>> is with other data sources as well.
>>>>>>>>>> Venc,
>>>>>>>>>> then check the hash the second time the script runs.
>>>>>>>>>> Jason
>>>>>>>>>> venc wrote:
>>>>>>>>>>> Hi david/jason,
>>>>>>>>>>> Please let me know.
>>>>>>>>>>> Thanks
Re: BIRT Chart with scripted data source invokes the method twice [message #256925 is a reply to message #256841] Wed, 03 October 2007 12:22 Go to previous message
Venc,
That may work. Just make sure to do a run task and then a render task.
Do not use the RunAndRender task.
Jason
venc wrote:
> hi jason,
>>> Venc,
>>> Jason
>>> venc wrote:
>>>> Jason,
>>>> me.
>>>>> Venc,
>>>>> Jason
>>>>>>> Venc,
>>>>>>> that currently.
>>>>>>> Jason
>>>>>>>> Thank you.
>>>>>>>>> Venc,
>>>>>>>>> Look at this entry.
>>>>>>>>> Jason
>>>>>>>>> venc wrote:
>>>>>>>>>> Hi jason,
>>>>>>>>>>> Venc,
>>>>>>>>>>> Jason
>>>>>>>>>>> venc wrote:
>>>>>>>>>>>> Hi david/jason,
>>>>>>>>>>>> Please let me know.
>>>>>>>>>>>> Thanks
Previous Topic:Re: Table Of Contents as a report item
Next Topic:How to restrict the number of columns in PDF format?
Current Time: Thu Oct 23 03:33:25 EDT 2025
Powered by FUDForum. Page generated in 0.05400 seconds
