Error running Eclipse 3.0 release on WinXP [message #256132] |
Sun, 27 June 2004 13:52  |
Originally posted by: reginald.reed.gmail.com
I get the following in the error logfile:
!SESSION Jun 26, 2004 22:10:21.855
eclipse.buildId=I200406251208
java.version=1.4.2_04
!ENTRY org.eclipse.osgi Jun 26, 2004 22:10:21.855
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:313)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
Any hints to get me going? I didn't have any problems with version 2.1.3.
Thanks!
--Reggie
Re: Error running Eclipse 3.0 release on WinXP [message #256575 is a reply to message #256510] |
Tue, 29 June 2004 02:07   |
After reading the last contributions in this thread, I asked a colleague
of mine to test Eclipse 3.0 on WinXP. AFAIK he used WinXP using the last
official patches (I can ask for details, if you are interested)
and installed the download into a fresh directory. Starting Eclipse he
didn't observe any problems, even used an old 2.1 plugin, which worked
successfully.
Do I correctly understand, that the described problems occur during
startup of Eclipse?
Greetings from Bremen,
Daniel Kruegler
A. Developer schrieb:
> Ditto; I just installed 3.0. on XP and get the same problem.
> Branko Kannenberg wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Jim McMaster wrote:
>> | At 1:26:49 PM on 6/27/2004, Pascal Rapicault wrote:
>> |>Make sure you downloaded the eclipse-3.0 SDK (around 85Mo).
>> | I did exactly that, and am having the identical problem. I never have
>> | had Eclipse 2.1. I am running Windows XP home and Sun's J2SDK1.4.2_04.
>> I can confirm this error. I never had this with M9/RC1/RC3.
>> Here is the log:
>> !SESSION Jun 28, 2004 11:34:49.15
>> java.version=1.4.2-rc1
>> java.vendor=Blackdown Java-Linux Team
>> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
>> !ENTRY org.eclipse.osgi Jun 28, 2004 11:34:49.16
>> !STACK 1
>> ~ at
>> ~ at
>> ~ at
>> ~ at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> ~ at
>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
>> ~ at
>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
>> ~ at java.lang.reflect.Method.invoke(Method.java:324)
>> ~ at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
>> ~ at org.eclipse.core.launcher.Main.run(Main.java:644)
>> ~ at org.eclipse.core.launcher.Main.main(Main.java:628)
>> Ciao, Branko.
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.2.4 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>> iD8DBQFA3+iSLUFCdqgeaZcRAjkzAKDNrLlGI0OwiPk4oRa5pEDIBb/6qgCg ygrq
>> pLXyemrEQoeKJMqexEYkQJ4=
>> =1WZ5
>> -----END PGP SIGNATURE-----
Re: Error running Eclipse 3.0 release on WinXP [message #256960 is a reply to message #256654] |
Wed, 30 June 2004 02:06  |
Originally posted by: manahan.NOSPAM.ca.ibm.com
Its a behaviour change I was told. Eclipse no longer provides the
application by default (got caught by this as well) the product needs to
provide it if none exist. If you have a mix of old (provided) and new
(not provided) configurations it won't work. (ie. ~/.eclipse say from
previous 3.0 builds)
One fix that may work (I haven't tried this as i just delete the
configuration directories)is to run with a -clean option once to refresh
the configuration.
Peter
> Hash: SHA1
> Hi there!
> | successfully.
> | startup of Eclipse?
> Yes.
> I unzipped eclipse into a fresh directory. But I have an existing
> configuration (workspace/.metadata and ~/.eclipse) which I don't want to
> delete. Switching back to RC3 works absolutely fine, so the 3.0final
> seems to have a bug.
> And apparently this bug is not OS dependent (linux and WinXP).
> Ciao, Branko.
> iD8DBQFA4WygLUFCdqgeaZcRAi5TAKDlgT9ilxRtB5IW5M/OrAd/z1+wOwCg n6ET
> 63hyHY3T3qhvz6YfB2cwkyY=
> =5ufO
FUDForum. Page generated in 0.05602 seconds
