Home » Language IDEs » Java Development Tools (JDT) » Running Cleanup as an Eclipse Application
Running Cleanup as an Eclipse Application [message #255947] Wed, 27 August 2008 17:28 Go to next message
Is there a way to run java code cleanup from the command line the same way
the formatter could be run?
Thanks in advance,
Hani
Re: Running Cleanup as an Eclipse Application [message #255956 is a reply to message #255947] Wed, 27 August 2008 18:26 Go to previous messageGo to next message
> way the formatter could be run?
> Thanks in advance,
> Hani
A Google search for 'code formatter command line Eclipse' turned up a
number of likely-looking articles, including this one:
http://www.peterfriese.de/formatting-your-code-using-the-ecl ipse-code-formatter/
Re: Running Cleanup as an Eclipse Application [message #255960 is a reply to message #255956] Wed, 27 August 2008 19:15 Go to previous messageGo to next message
>> Thanks in advance,
>> Hani
Oh, my apologies, I think on re-reading that I misunderstood your
question. Sorry, that article is probably not an answer to your question.
Re: Running Cleanup as an Eclipse Application [message #255964 is a reply to message #255947] Thu, 28 August 2008 03:03 Go to previous message
No.
Dani
> Thanks in advance,
> Hani
Previous Topic:Re: Java Search Suggestion
Next Topic:Prevent eclipse from building a project when any intermediate files are changed
Current Time: Sun Sep 14 17:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.05782 seconds
