| How to install Eclipse in Suse Linux [message #255907] |
Fri, 09 May 2008 02:49  |
Originally posted by: sandeep.drassautomech.com
Dear Sir/Madam,
we are using Suse Linux for our project Digital Readout
System
and we are porting linux to ARM platform,also we are using Eclipse for our
development purpose and we are finding problem in installing Eclipse the
problem is "org.eclipse.platform.ide" ,"java.lang.RuntimeException: No
application id has been found"& root constraints are not resolved. Please
help in resolving this problem.
Thanks & Regards
SANDEEP G R
Design Engineer,
Drass Mechatronics and Machinery Private Limited,
#782/20-1,1st Floor,6th
Cross,L.N.Colony, Yeshwanthpur,
Bangalore-560022,
India.
Phone:+91-80-41275171
Mobile:+91-9845082436
E-mail:sandeep@drassautomech.com
| Re: How to install Eclipse in Suse Linux [message #255940 is a reply to message #255907] |
Fri, 09 May 2008 06:38   |
SANDEEP,
Thinks like using a poor version of the JVM tends to cause problems. I
think it's gcj in particular that generally won't work...
Try running with the flags -clean -debug and keep close track of whats
in the <workspace>/.metadata/.log (if one is produced at all).
SANDEEP G R wrote:
> Dear Sir/Madam,
> Readout System
> our development purpose and we are finding problem in installing
> Eclipse the problem is "org.eclipse.platform.ide"
> ,"java.lang.RuntimeException: No application id has been found"& root
> constraints are not resolved. Please help in resolving this problem.
> Thanks & Regards
> SANDEEP G R
> Design Engineer,
> Drass Mechatronics and Machinery Private Limited, #782/20-1,1st Floor,6th
> Cross,L.N.Colony, Yeshwanthpur, Bangalore-560022,
> India.
| Re: How to install Eclipse in Suse Linux [message #255976 is a reply to message #255907] |
Fri, 09 May 2008 10:31  |
Originally posted by: dcarver.starstandard.org
SANDEEP G R wrote:
> Dear Sir/Madam,
> System
> our development purpose and we are finding problem in installing Eclipse
> the problem is "org.eclipse.platform.ide" ,"java.lang.RuntimeException:
> No application id has been found"& root constraints are not resolved.
Best thing you can do is not use the version of eclipse that is in the
SUSE repository, but get it and install it from the Eclipse website.
It'll be more current as well.
You also should not run your eclipse installation with gcj, as it's an
unsupported Java runtime. You are better off using ICETea, Sun, BEA, or
IBM's java jres.
Dave
FUDForum. Page generated in 0.09055 seconds
