Home » Eclipse Projects » Eclipse Platform » AMD64 processor. Did Eclipse need to do anything special? VE isn't working on it.
AMD64 processor. Did Eclipse need to do anything special? VE isn't working on it. [message #255626] Fri, 25 June 2004 11:41 Go to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Did Eclipse need to do any special java code for working on a Linux
AMD64 system?
Someone just reported that the VE doesn't work right on it. They are
getting wierd code being generated by us. We aren't using any JNI code.
And we are using straight updates to the jdt idocuments using insert
positions and such. But code is being inserted in wierd spots from where
it should be.
int stays 32 bit in a 64 bit system in java doesn't it? We don't have to
worry about larger standard ints, do we?
Any ideas would be appreciated.
Thanks, Rich Kulp
Re: AMD64 processor. Did Eclipse need to do anything special? VE isn't working on it. [message #255630 is a reply to message #255626] Fri, 25 June 2004 11:56 Go to previous messageGo to next message
Originally posted by: thomas_maeder.ch.ibm.com
Ints stay ints, you're right, so any pure java program shoud just work.
I figure the problem starts when you have native libraries (SWT, anyone?).
Thomas
Rich Kulp wrote:
> AMD64 system?
> it should be.
Re: AMD64 processor. Did Eclipse need to do anything special? VE isn't working on it. [message #255637 is a reply to message #255630] Fri, 25 June 2004 11:57 Go to previous message
Oh, and of course your VM needs to be 64bit safe (i.e. not make wrong
assumption about native datatype sizes.
> Thomas
> Rich Kulp wrote:
>> Hi,
>> AMD64 system?
>> code. And we are using straight updates to the jdt idocuments using
>> insert positions and such. But code is being inserted in wierd spots
>> from where it should be.
>> to worry about larger standard ints, do we?
Previous Topic:RC3: Export Feature Fails
Next Topic:[JFace] Creating a filtered TreeViewer with deferred tree building
Current Time: Fri Jul 18 17:44:31 EDT 2025
Powered by FUDForum. Page generated in 0.16049 seconds
