Home » Newcomers » Newcomers » eclipse keys source
eclipse keys source [message #255435] Sun, 04 May 2008 10:31 Go to next message
I want to run different eclipse keys like CTRL+SHIFT+O on all files under
directory and sub directory.
Is that possible?
Where can I find the source for each key so I can modify and run it from
command-line?
Idan
Re: eclipse keys source [message #255526 is a reply to message #255435] Mon, 05 May 2008 18:53 Go to previous messageGo to next message
I don't think it's an easy task to reuse this stuff on the console.
In the case of Organize Imports, you can right click in your
project/folder/whatever, Source > Organize Imports.
Greets
Benny
idan72 wrote:
> under directory and sub directory.
> Is that possible?
> command-line?
> Thanks
> Idan
Re: eclipse keys source [message #255554 is a reply to message #255526] Tue, 06 May 2008 03:30 Go to previous messageGo to next message
Thanks.
Is there a way to implement the same for other keys like CTRL+I or other
if I can't use the source?
Idan
Re: eclipse keys source [message #255558 is a reply to message #255554] Tue, 06 May 2008 04:22 Go to previous message
Right click, Source > Format? ;)
If you need this for other things, you maybe could write a little plugin
to call the corresponding command bound to the keybinding with different
selections.
Greets
Benny
idan72 wrote:
> Thanks.
> Thanks
> Idan
Previous Topic:Javadoc validation
Next Topic:EPF Capability Pattern
Current Time: Tue Jul 22 06:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.07432 seconds
