Home » Eclipse Projects » Eclipse Platform » Java Perspective is blank - cannot get back
Java Perspective is blank - cannot get back [message #255449] Thu, 24 June 2004 17:37 Go to next message
Originally posted by: jasmith.marthastewart.com
Version: 2.1.1
Build id: 200306271545
In my Java Perspective, the Hierarchy window is blank with the message:
"To display the type hierarchy, select a type (for example in the outline
view or in the editor), and select 'Open Type Hierarchy' menu option.
Alternatively, you can drag and drop an element (e.g. project, package,
type) onto this view."
The Outline window is blank with the message:
"An outline is not available."
I don't konw what I did, and I can't seem to recover. Can someone give me
some cluse how to recover?
Re: Java Perspective is blank - cannot get back [message #255453 is a reply to message #255449] Thu, 24 June 2004 17:41 Go to previous messageGo to next message
I had a handful of projects in my Java Perspective before it went blank.
It would take quite some time to recreate these. Is there any way to
recover?
Jim wrote:
> Version: 2.1.1
Re: Java Perspective is blank - cannot get back [message #255523 is a reply to message #255453] Fri, 25 June 2004 01:44 Go to previous messageGo to next message
Do you have a Java file open when these messages appear?
> recover?
> Jim wrote:
>>Version: 2.1.1
Re: Java Perspective is blank - cannot get back [message #255602 is a reply to message #255523] Fri, 25 June 2004 09:28 Go to previous message
Initially no, but even when I go to open a Java file from the File menu
(files last opened), the file will open up, but the Java Perspective pane
is still blank with the error message.
> > recover?
> > Jim wrote:
> >>Version: 2.1.1
Previous Topic:Problem with Lomboz JSP editor
Next Topic:Newbie Question: Can't run eclipse
Current Time: Thu Nov 06 14:11:07 EST 2025
Powered by FUDForum. Page generated in 0.03688 seconds
