Home » Newcomers » Newcomers » Error: CharScanner; panic: ClassNotFoundException:
Error: CharScanner; panic: ClassNotFoundException: [message #255410] Sat, 03 May 2008 12:11 Go to next message
Originally posted by: npchala.yahoo.com
I have built a project(isis.anp) which I need to run on Eclipse 3.2. I
need to run this as a separate eclipse application ("Run as Eclipse
Application"). So i created a simple RCP plugin and imported isis.anp
project.
When i tried to run this RCP plugin as 'Run as Eclipse Application' it
gives an error as 'CharScanner; panic: ClassNotFoundException:
isis.anp.CToken'. but when i tryed to simply run it as 'Run as Java
Application' it works fine. But i need to run it as a plug-in. I set the
runtime classpath in the MANIFEST file to the imported project.
I would be thankful if anybody could help to figure out this problem. The
isis.anp separately also works fine.
Thank you,
C.Lah
Re: Error: CharScanner; panic: ClassNotFoundException: [message #255418 is a reply to message #255410] Sat, 03 May 2008 14:14 Go to previous message
Hey,
See if I understand you correctly. You need to run smth. as a plugin that
depends on a project that is in your workspace? Can you post your manifest
file?(I asked you to do so before on the antlr mailing list..)
Felix
C.Lah wrote:
> project.
> The isis.anp separately also works fine.
> Thank you, C.Lah
Previous Topic:Plugin classloader error in 3.3 not in 3.2
Next Topic:Request the quote of Eclipse part
Current Time: Tue Oct 28 09:07:31 EDT 2025
Powered by FUDForum. Page generated in 0.09855 seconds
