Home » Archived » BIRT » Printing reports and the cancel button in progressbar
Printing reports and the cancel button in progressbar [message #253671] Tue, 28 August 2007 06:03 Go to next message
sorry for multi posting, but another error/question occures my report
engine.
When i use the button "Print report on the server" a printing dialog
opens. But in this dialog no printer is available. I just tried several
operating systems. On Windows no printer is available, on Linux (Ubuntu)
the standard printer is "not-accepting-jobs". The printers have been
installed as a local printer over the tcp-ip interface.
How could i use this printing function correctly?
The other concern is the ProgressBar. When i generate a reaaaallyyyy big
report and it takes too much time, the user could press the "Cancel"
button. But when this button is clicked and the question afterwards is
accepted, the progess will go on. The page is locating another one, yes,
but if i have a look on the system utilisation, the cpu efficiency is
about 100%.
Is it possible to cancel the progress by pressing the "Cancel" button? And
how could i use the printer on the server?
Bye Tom
Re: Printing reports and the cancel button in progressbar [message #253948 is a reply to message #253671] Thu, 30 August 2007 04:41 Go to previous messageGo to next message
Print on server client need Printer which supports postscript print. You
should install a Printer in your machine which support postscript print
otherwise the printer list will be blank.
"Tom" <t.doberstein@stv-electronic.de> wrote in message
news:93e2c9fc67cf2c19bd5d58cf129d756a$1@www.eclipse.org...
> Hello,
> engine.
> about 100%.
> Bye Tom
Re: Printing reports and the cancel button in progressbar [message #254340 is a reply to message #253671] Tue, 04 September 2007 05:39 Go to previous messageGo to next message
for generating a valid print under Windows i installed the
AdobePS
Printer
on my server.
This Generic Printer is an interface to your printer, for instance
"Standard TCP/IP Port". It works fine ecpecting a little exception: When i
create a report in landscape format the driver will only print in portrait
format.
Is it actually possible to print a report in landscape format from the
BIRT engine? Or is it a bug from the Adobe PostScript printer?
Bye Tom
Re: Printing reports and the cancel button in progressbar [message #254343 is a reply to message #253671] Tue, 04 September 2007 06:00 Go to previous messageGo to next message
i forget to say that an exeption in the console, while trying to print,
occurs:
[Fatal Error] :-1:-1: Premature end of file.
04.09.2007 11:48:10
org.eclipse.birt.report.engine.layout.pdf.font.FontConfigRea
der parseConfigFile
WARNUNG: Premature end of file.
org.xml.sax.SAXParseException: Premature end of file.
at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
at
org.eclipse.birt.report.engine.layout.pdf.font.FontConfigRea der.parse
ConfigFile(FontConfigReader.java:163)
at
ConfigFile(FontConfigReader.java:128)
at
FormatRelatedConfigFile(FontConfigReader.java:119)
at
org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.g etFontMan
ager(FontHandler.java:230)
at
org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.s etFormat(
FontHandler.java:261)
at
org.eclipse.birt.report.engine.layout.pdf.font.FontHandler.<init >(Fon
tHandler.java:103)
at
org.eclipse.birt.report.engine.layout.pdf.font.FontSplitter. <init>(Fo
ntSplitter.java:48)
at
org.eclipse.birt.report.engine.layout.pdf.text.ChunkGenerato r. <init>(
ChunkGenerator.java:34)
at
org.eclipse.birt.report.engine.layout.pdf.PDFTextLM$Composit or. <init>
(PDFTextLM.java:235)
at
org.eclipse.birt.report.engine.layout.pdf.PDFTextLM.<init>(PDFTextLM.
java:82)
at
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory$Con
tentVisitor.handleText(PDFLayoutManagerFactory.java:217)
at
tentVisitor.visitLabel(PDFLayoutManagerFactory.java:142)
at
org.eclipse.birt.report.engine.content.impl.LabelContent.acc ept(Label
Content.java:121)
at
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory.cre
ateLayoutManager(PDFLayoutManagerFactory.java:73)
at
org.eclipse.birt.report.engine.layout.pdf.PDFLineAreaLM.hand leChild(P
DFLineAreaLM.java:167)
at
org.eclipse.birt.report.engine.layout.pdf.PDFLineAreaLM.trav erseChild
ren(PDFLineAreaLM.java:150)
at
org.eclipse.birt.report.engine.layout.pdf.PDFStackingLM.layo utChildre
n(PDFStackingLM.java:118)
at
org.eclipse.birt.report.engine.layout.pdf.PDFAbstractLM.layo ut(PDFAbs
tractLM.java:132)
at
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .layoutCh
ildNode(PDFBlockStackingLM.java:109)
at
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .traverse
Children(PDFBlockStackingLM.java:89)
at
at
tractLM.java:132)
at
at
at
at
tractLM.java:132)
at
at
at
at
tractLM.java:132)
at
org.eclipse.birt.report.engine.layout.pdf.PDFRowLM.traverseC hildren(P
DFRowLM.java:88)
at
at
tractLM.java:132)
at
at
at
org.eclipse.birt.report.engine.layout.pdf.PDFTableLM.travers eChildren
(PDFTableLM.java:108)
at
at
tractLM.java:132)
at
at
at
at
tractLM.java:132)
at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layoutFo oter(PDFP
ageLM.java:179)
at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.initiali ze(PDFPag
eLM.java:84)
at
n(PDFStackingLM.java:116)
at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layout(P DFPageLM.
java:212)
at
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layou
tReport(PDFReportLayoutEngine.java:64)
at
t(PDFReportLayoutEngine.java:87)
at
org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange Render.re
nder(RenderTask.java:501)
at
org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.
java:254)
at
org.eclipse.birt.report.service.ReportEngineService.renderRe port(Unkn
own Source)
at
org.eclipse.birt.report.service.BirtViewerReportService.rend erReport(
Unknown Source)
at
org.eclipse.birt.report.service.actionhandler.BirtRenderRepo rtActionH
andler.__execute(Unknown Source)
at
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandl
er.execute(Unknown Source)
at
org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragm
ent.doService(Unknown Source)
at
ent.service(Unknown Source)
at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(Unknow n
Source)
at
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGe
t(Unknown Source)
at
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPo
st(Unknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBas
e.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(Appl
icationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationF
ilterChain.java:206)
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperV
alve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextV
alve.java:175)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(A uthentica
torBase.java:433)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.j
ava:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.j
ava:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineVal
ve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.jav
a:263)
at
org.apache.coyote.ajp.AjpAprProcessor.process(AjpAprProcesso r.java:41
9)
at
org.apache.coyote.ajp.AjpAprProtocol$AjpConnectionHandler.pr ocess(Ajp
AprProtocol.java:394)
at
org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoin t.java:15
08)
When i print a test page in landscape format at the AdobePS printer this
page will be printed correctly in landscape format. But not these printed
from BIRT engine.
Which file meant in the exception?
Bye Tom
Re: Printing reports and the cancel button in progressbar [message #255271 is a reply to message #253671] Thu, 13 September 2007 05:42 Go to previous messageGo to next message
i havent found my errors until now. So i disabled the "Printing on server"
function and only use "Printing as PDF".
Thanks for helping anyway.
Bye Tom
Re: Printing reports and the cancel button in progressbar [message #1194576 is a reply to message #255271] Mon, 18 November 2013 10:32 Go to previous message
Hi Tom,
I could use your help. Could you please tell me how did you disable the "Print to Server" option on the birt reports?
Thank you so much for the help,
Dinesh
Previous Topic:Facing problem with Pojo Datasource in 4.3
Next Topic:Building BIRT viewer locally (4.3.x)
Current Time: Fri Jul 18 22:07:39 EDT 2025
Powered by FUDForum. Page generated in 0.04977 seconds
