ITypeParameter is not an IAnnotatable [message #255197] |
Wed, 23 July 2008 13:50  |
I try to use the jdt annotation API, and I stumble as I can't get any
annotations from method parameters.
IField, ILocalVariable, IMethod, IPackageDeclaration, IType are all
IAnnotatable but ITypeParameter is not.
Why is this, better how could I get the annotation from a parameter ?
greetings, urs.
Re: ITypeParameter is not an IAnnotatable [message #255302 is a reply to message #255197] |
Sat, 26 July 2008 12:26   |
"urs zeidler" <ich@urszeidler.de> wrote in message
news:g67r13$6nb$1@build.eclipse.org...
I don't believe ITypeParameter has anything to do with method parameters.
I think ITypeParameter describes type parameters, for instance 'T' in the
following declaration:
class Foo<T> {
T getT() { ... }
void putT(T t) { ... }
And type parameters are not annotatable, in the current definition of Java
(pending JSR-308).
Since IMethod.getParameterTypes returns type signatures rather than IType[],
I am not sure the Java Model will give you information at this level of
detail - I think you may have to use the DOM AST instead, or use APT.
Re: ITypeParameter is not an IAnnotatable [message #255318 is a reply to message #255302] |
Tue, 29 July 2008 03:34  |
You are absolute right.
> (pending JSR-308).
Indeed.
Yes ITypeParameter was the only interface about parameters in the range
of IMethode I found, that's why I mixed it up. And funny is I have
already worked with ITypeParameter in the same UML importer, but in an
other aspect (as template parameter, what they are).
So it looks to me as there is not annotation support on parameter.
That's really pity, I wanted to import the annotation as stereotypes in
an UML model import, now I can't cover parameters.
Perhaps I should open a feature request for it.
thanks for your answer, greetings, urs.
FUDForum. Page generated in 0.03488 seconds
