Home » Eclipse Projects » DTP » DTP 1.0: Connection profiles don't get saved between Eclipse sessions?
DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #25391] Thu, 11 January 2007 12:09 Go to next message
Originally posted by: last-name-first-init.yahoo.com
Using DTP 1.0, I create a connection profile to a Derby 10.1 embedded
database. Everything works as expected. But after I shut down Eclipse
and then restart it, there are no connection profiles in the Data Source
Explorer view (under Databases). Is this a known bug or am I doing
something wrong?
--Sugato
Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #25428 is a reply to message #25391] Thu, 11 January 2007 13:21 Go to previous messageGo to next message
From the Eclipse error log (below), the problem appears to be
converting from byte to char when reading in the connection profile data.
!ENTRY org.eclipse.datatools.connectivity 4 10001 2007-01-11 12:02:21.267
!MESSAGE Error loading connection profile data.
!STACK 1
org.eclipse.core.runtime.CoreException: Error loading connection profile
data.
at
org.eclipse.datatools.connectivity.internal.ConnectionProfil eMgmt.loadCPs(ConnectionProfileMgmt.java:479)
at
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.loadProfiles(InternalProfileManager.java:566)
at
org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfiles(InternalProfileManager.java:84)
!SUBENTRY 1 org.eclipse.datatools.connectivity 4 -1 2007-01-11 12:02:21.307
!STACK 0
sun.io.MalformedInputException
at sun.io.ByteToCharUTF8.convert(ByteToCharUTF8.java:262)
at sun.nio.cs.StreamDecoder$ConverterSD.convertInto(StreamDecod er.java:314)
at sun.nio.cs.StreamDecoder$ConverterSD.implRead(StreamDecoder. java:364)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:250)
at java.io.InputStreamReader.read(InputStreamReader.java:212)
at java.io.BufferedReader.fill(BufferedReader.java:157)
Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #25508 is a reply to message #25428] Fri, 12 January 2007 14:16 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi Sugato...
Can you provide some details about your environment? We've seen this kind of
issue before, but thought we had it solved.
--Brian Fitzpatrick
"Sugato Bagchi" <last-name-first-init@yahoo.com> wrote in message
news:eo5v6s$i18$1@utils.eclipse.org...
> From the Eclipse error log (below), the problem appears to be converting
> !STACK 1
> data.
> at
> at
> at
> 12:02:21.307
> !STACK 0
> at
Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #25694 is a reply to message #25508] Sat, 20 January 2007 03:47 Go to previous messageGo to next message
I had the same problem, in my Eclipse's shorcut the vm was
IBM\Java142\jre\bin\javaw.exe; then I changed it to: jdk1.5.0_01 and now
DTO works fine.
Riccardo Cattania
Brian Fitzpatrick ha scritto:
> Hi Sugato...
> --Brian Fitzpatrick
>> !STACK 1
>> data.
>> at
>> at
>> at
>> 12:02:21.307
>> !STACK 0
>> at
Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #25870 is a reply to message #25694] Mon, 22 January 2007 17:29 Go to previous message
Originally posted by: john.graham.sybase.com
Riccardo wrote:
> IBM/Java/142/jre/bin/javaw.exe; then I changed it to: jdk1.5.0_01 and now
> DTO works fine.
> Regards
> Riccardo Cattania
This would be consistent with other reports (all have involved the IBM
VM), but no one had tested it by switching as you did to see if that
solves the problem. Thank you for this clue, and we'll be looking into it.
-- John Graham
Eclipse Data Tools Platform PMC Chair
Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #583943 is a reply to message #25391] Thu, 11 January 2007 13:21 Go to previous message
!STACK 1
data.
at
at
at
!STACK 0
Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #583969 is a reply to message #25428] Fri, 12 January 2007 14:16 Go to previous message
Hi Sugato...
--Brian Fitzpatrick
> !STACK 1
> data.
> at
> at
> at
> 12:02:21.307
> !STACK 0
> at
Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #584057 is a reply to message #25508] Sat, 20 January 2007 03:47 Go to previous message
DTO works fine.
Riccardo Cattania
> Hi Sugato...
> --Brian Fitzpatrick
>> !STACK 1
>> data.
>> at
>> at
>> at
>> 12:02:21.307
>> !STACK 0
>> at
Re: DTP 1.0: Connection profiles don't get saved between Eclipse sessions? [message #584136 is a reply to message #25694] Mon, 22 January 2007 17:29 Go to previous message
Riccardo wrote:
> DTO works fine.
> Regards
> Riccardo Cattania
-- John Graham
Previous Topic:Triggers created in different schema than table it references
Next Topic:db2 express C connection
Current Time: Wed Nov 12 02:03:46 EST 2025
Powered by FUDForum. Page generated in 0.05100 seconds
