Ecipse 3.3 -> 3.4 Junit Problems [message #255049] |
Tue, 15 July 2008 16:42  |
I recently downloaded Ganymede JEE distro from the eclipse website. After
installing and creating a brand-new workspace, i imported a project from
my 3.3 workspace.
Once i did this, i tried to run a JUnit (4.4) test, and it gave me a
java.lang.ClassNotFoundException. The class that wasn't found was the
JUnit test class! I tried several things which narrowed it down to this:
If i create a brand-new project within v3.4, JUnit works without a hitch.
If i import a project from a 3.3 workspace or (and this is important) if i
check-out a project from CVS that was developed under Eclipse 3.3, I
continue to get the error.
It seems that I can not run any JUnit 4.4 from any project that wasn't
created by Ganymede.
This is very serious issue as all of my old projects were developed under
3.3, and but none of my test cases will run in 3.4.
Has anyone else experienced this or has found a solution to it? Any help
is much appreciated. Thank you.
FUDForum. Page generated in 0.05019 seconds
