Home » Eclipse Projects » Eclipse Platform » Error in org.eclipse.core.runtime with RC3
Error in org.eclipse.core.runtime with RC3 [message #254424] Mon, 21 June 2004 19:29 Go to next message
I upgraded from 3.0m9 to RC3 and I have the following problem.
I have a multipage editor that comes up ok when I select the file from
the navigator. However, if I leave the file up and exit eclipse and
then reenter I get the following error:
An error has occurred when creating this editor
When I look in the error log I see the following:
Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
An exception stack trace could not be found.
This error results when I run in the runtime-workbench and with deployed
plugins. It worked in 3.0m9
Brian Kozitza
Re: Error in org.eclipse.core.runtime with RC3 [message #254707 is a reply to message #254424] Tue, 22 June 2004 12:46 Go to previous messageGo to next message
Originally posted by: chaves.nospam.inf.ufsc.br.ok
Open a PR and make sure you include your log file
(<workspace>/.metadata/.log)
> Brian Kozitza
Re: Error in org.eclipse.core.runtime with RC3 [message #254748 is a reply to message #254707] Tue, 22 June 2004 13:31 Go to previous messageGo to next message
Never mind it was my problem. Apparently something changed in the
startup and I was not checking for a null pointer. The log file showed
a stacktrace that allowed me to find it.
In previous versions, the stacktrace showed up in the error log dialog.
The error dialog for this error said that "An exception stack trace
could not be found." Perhaps I should open a PR for this?
>>Brian Kozitza
Re: Error in org.eclipse.core.runtime with RC3 [message #255005 is a reply to message #254748] Wed, 23 June 2004 12:56 Go to previous message
The Error log view will show you that message for Log entries that do not
include exceptions. Sometimes, omitting a stack trace is a deliberate
choice when someone wants to reduce the level of noise in the log
(although it is always a good idea to provide a debug option that allows
developers to enable logging of the exxception if necessary).
It is usually a good idea to open PRs (after checking nobody reported
something similar) for inadequate/strange behavior. In the worst case,
someone will mark the bug as invalid, and explain why.
Rafael
> >>Brian Kozitza
Previous Topic:Build.properties: Binary vs Source Build
Next Topic:add item to "Run" popup menu category
Current Time: Wed Sep 17 04:18:54 EDT 2025
Powered by FUDForum. Page generated in 0.03046 seconds
