Home » Newcomers » Newcomers » Jboss as Default server in Eclipse
Jboss as Default server in Eclipse [message #254123] Thu, 17 April 2008 08:00 Go to next message
Originally posted by: susmitha.yahoo.com
I have downloaded Jboss IDE for eclipse and also configured a new server
using the Servers View.
I am using Eclipse3.3.2 and JBoss5.0.0. I am able to start JBoss from the
command prompt.
Now I have 2 problems
1) I am not able to see anything in the dropdown box in
window->preferences->JBoss-IDE-Launcher to select this JBoss as my default
server.
What should be done?
2) When I right click on the server in Servers view and say 'run' , I get
a error message saying server didnot resond in 50 sec..
How can I change this timeout period because my JBoss is taking around
1min 20sec to start(from command promt).
Susmitha
Re: Jboss as Default server in Eclipse [message #254134 is a reply to message #254123] Thu, 17 April 2008 11:01 Go to previous messageGo to next message
Originally posted by: sinha.vivisimo.com
In the server view, double click the server you added. You should see
the Overview page. There is a place to set "Timeouts" (which is 50s by
default).
HTH
-tanmay
Susmitha wrote:
> Hi
> the command prompt.
> default server.
> get a error message saying server didnot resond in 50 sec..
> Thanks Susmitha
Re: Jboss as Default server in Eclipse [message #254138 is a reply to message #254123] Thu, 17 April 2008 11:34 Go to previous messageGo to next message
Originally posted by: emilba.yahoo.com
use this.
Window -> Preferences -> Server -> Server Timeout Delay -> Unlimited
emil.
Susmitha wrote:
> Hi
> the command prompt.
> default server.
> Thanks Susmitha
Re: Jboss as Default server in Eclipse [message #254205 is a reply to message #254138] Fri, 18 April 2008 00:49 Go to previous messageGo to next message
Thanks for the reply...
But there is still one question unanswered...
I am not able to see this server in the
window->preferences->JBoss-IDE-Launcher->default sever dropdown box....
or is there any other way set this server as the default server so that I
can use the toolbar icons to start,stop my server.
Susmitha
Re: Jboss as Default server in Eclipse [message #254216 is a reply to message #254205] Fri, 18 April 2008 06:20 Go to previous messageGo to next message
The problem here is that when I try to deploy an application by right
click on the project and go to 'Deploy to' , I cannot see anything in the
'Target Choices' dialog ..
How can I deploy the app now?
Susmitha
Re: Jboss as Default server in Eclipse [message #254528 is a reply to message #254216] Tue, 22 April 2008 05:56 Go to previous messageGo to next message
Can anybody help me in this regard..
Susmitha
Re: Jboss as Default server in Eclipse [message #254590 is a reply to message #254528] Wed, 23 April 2008 05:24 Go to previous message
If I'm reading this properly, you're mentioning a preferences page that
is not standard Eclipse, but rather is a preference page for the JBoss
IDE. Your question should be posed on a JBoss IDE forum.
Good luck,
Wayne
On Tue, 2008-04-22 at 09:56 +0000, Susmitha wrote:
> Hi
> Thanks
> Susmitha
Previous Topic:automatically select the right mirror?
Next Topic:Javadoc and JUnit tests
Current Time: Thu Nov 06 17:24:48 EST 2025
Powered by FUDForum. Page generated in 0.09191 seconds
