| [XPDL] Greetings [message #25416] |
Mon, 02 April 2007 19:44  |
Eclipse User  |
Originally posted by: steve.egbert.bull.com
Greetings:
My name is Steve Egbert and I work for Bull.
I work with Emmanuel and Miguel.
For the past year, and then some, I have been responsible for Bull's
graphical XPDL editor, which is called ProEd. It implements most of XPDL 1,
plus additional features that are available in the Bonita workflow engine,
so I have a passing fair familiarity with XPDL 1.0. We are in the final
stages of placing it into open source on ObjectWeb, under the Bonita
project.
I have added a considerable number of new featrues to ProEd, in the time I
have been responsible for it, and most recently have converted it to run
both as the original stand alone/webstart application and as an Eclipse
plugin. It uses the Swing based JGraph component for the node diagrams, and
so I have used the Swing-AWT bridge classes in implementing the plugin
version. The data model predates modeling frameworks, and is pretty much
based on the structure of the XPDL schema. I have attached some small
pictures of a couple of the graphical views of an XPDL that are available in
the ProEd plugin, in case someone is interested in seeing what it looks
like.
Steve
FUDForum. Page generated in 0.04398 seconds
