Home » Archived » OHF » ATNA Support update for the OHF IHE Plugins and OHF Bridge
ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #24359] Wed, 22 November 2006 01:19 Go to next message
Originally posted by: rgd.us.ibm.com
We've succesfully tested ATNA TLS with the MESA TLS Tests, and with the
IBM test services on lswin10.dfw.ibm.com.
As Sarah mentioned in another post, we have a bug open against the NIST
test server. For some reason we are getting a handshake failure with
that one system - all the others we've tested against are doing TLS just
fine with the OHF plugins.
One important note we've raised with the IHE, and are awaiting a
response - is that the Sun JVMs 1.4.2 and 1.5.x don't provide support
for the TLS cipher TLS_RSA_WITH_NULL_SHA. This is specified by the
ATNA profile as the unencrypted cipher to use. Currently we've
substituted the simliar cipher SSL_RSA_WITH_NULL_SHA in the OHF ATNA
code, and with this cipher we've succesfully passed the required MESA
TLS tests 1221, 1222, 1223.
regards,
glenn deen (IBM OHF team)
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #24446 is a reply to message #24359] Thu, 23 November 2006 01:11 Go to previous messageGo to next message
> regards,
Update - SSL_RSA_WITH_NULL_SHA is 100% equivalent in Java to
TLS_RSA_WITH_NULL_SHA. The name is different, but the actual cipher ID
sent to the server is the same as TLS_RSA_WITH_NULL_SHA. I've updated
the ATNA transport code with this cipher name. So it's now good to go.
I've tested it with MESA and it's succesfully negotating the TLS handshake.
-glenn
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #25333 is a reply to message #24446] Wed, 29 November 2006 04:08 Go to previous messageGo to next message
Originally posted by: sdoyle.medcommons.net
How do we test the TLS connections from the bridge to the MESA servers
(e.g., Test #s 11141, 11142, 11143)?
I see the JUnit code for the plugins - but how do we test this in the
context of the bridge? Or - do we claim that because you have passed these
tests that this is adequate?
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #25373 is a reply to message #25333] Wed, 29 November 2006 14:29 Go to previous messageGo to next message
Originally posted by: donnie.gooch.pointclearsolutions.com
I am (capmed) reusing IBM's, waiting on verification now.
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #25413 is a reply to message #25373] Wed, 29 November 2006 15:11 Go to previous messageGo to next message
Hi Donnie -
Did you get the verification files from IBM or did you just write
something saying that the bridge handled this case?
Thanks!
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #25452 is a reply to message #25333] Wed, 29 November 2006 15:21 Go to previous message
The OHF Bridge has passed these tests for you. You are to what is in the
JUNIT Documentation. We are working on updating
http://wiki.eclipse.org/index.php/OHF:ATNA_2007_MESA_Tests. Please
refere to the links in the ATNA Test table here:
http://wiki.eclipse.org/index.php/IHE_Connectathon_2007#Deta iled_MESA_Test_Info
- Sarah
> these tests that this is adequate?
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #575451 is a reply to message #24359] Thu, 23 November 2006 01:11 Go to previous message
> regards,
-glenn
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #576318 is a reply to message #24446] Wed, 29 November 2006 04:08 Go to previous message
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #576336 is a reply to message #25333] Wed, 29 November 2006 14:29 Go to previous message
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #576393 is a reply to message #25373] Wed, 29 November 2006 15:11 Go to previous message
Hi Donnie -
Thanks!
Re: ATNA Support update for the OHF IHE Plugins and OHF Bridge [message #576403 is a reply to message #25333] Wed, 29 November 2006 15:21 Go to previous message
http://wiki.eclipse.org/index.php/OHF:ATNA_2007_MESA_Tests Please
- Sarah
Previous Topic:new Audit messages on the server
Next Topic:TLS with NIST now availiable on OHF Bridge
Current Time: Fri Nov 07 14:24:52 EST 2025
Powered by FUDForum. Page generated in 0.05225 seconds
