Home » Eclipse Projects » Buckminster dev » SVN access for new commiters
SVN access for new commiters [message #25209] Fri, 05 September 2008 08:36 Go to next message
Hi everyone,
At last ...I manage to get my ssh+svn running ...
The guide ( http://wiki.eclipse.org/Committer_access_(Buckminster) ) is very complicated and not very up to date. For instance, for the client side, I managed to get it all running by adding my private key to Eclipse and using the SVNKit Subclipse implementation (Pure Java) - no tortoise or putty peageant needed.
Isn't it worth rewriting the document in order for the new committers to be "up & running" quicker ?
I can do for the windows part but as I'm not sure it's also effective for the other platforms I don't want to break everything.
What would you recommend ?
Guillaume
Re: SVN access for new commiters [message #25253 is a reply to message #25209] Fri, 05 September 2008 09:01 Go to previous messageGo to next message
I thought everything was ok because I succeeded in connecting to svn+ssh://dev.eclipse.org/svnroot/tools/org.eclipse.buckmins ter . I can connect, fetch, compare but commiting leads to
> commit -m "Adding .qualifier to plugins" T:/travail/src/BuckminsterWorkspace/plugins/org.eclipse.buck minster.executor.test/META-INF/MANIFEST.MF T:/travail/src/BuckminsterWorkspace/plugins/org.eclipse.buck minster.executor/META-INF/MANIFEST.MF T:/travail/src/BuckminsterWorkspace/plugins/org.eclipse.buck minster.fetcher/META-INF/MANIFEST.MF
> svn: Commit failed (details follow):
> svn: Authorization failed
Can anyone help me ?
Guillaume
Guillaume CHATELET wrote:
> Hi everyone,
> Regards,
> Guillaume
Re: SVN access for new commiters [message #25291 is a reply to message #25253] Fri, 05 September 2008 17:21 Go to previous messageGo to next message
Hi Guillaume,
Try using password based authentication instead. That way you don't need the the generated
ssh keys, putty, etc.
Someone ought to revise the instructions on the wiki so that the password approach is the
recommended one. I just haven't had time to do it yet. Sorry.
Thomas Hallgren
> Best regards,
> Guillaume
>> Hi everyone,
>> Regards,
>> Guillaume
Re: SVN access for new commiters [message #25332 is a reply to message #25291] Wed, 10 September 2008 06:07 Go to previous messageGo to next message
I described that for the "Mac part", but did not take the time to check
what was needed on Windows at the same time.
And yes, the wiki page needs to be cleaned up - it is a mess.
- henrik
Thomas Hallgren wrote:
> Hi Guillaume,
> the the generated ssh keys, putty, etc.
> password approach is the recommended one. I just haven't had time to do
> it yet. Sorry.
> Regards,
> Thomas Hallgren
>> Best regards,
>> Guillaume
>>> Hi everyone,
>>> Regards,
>>> Guillaume
Re: SVN access for new commiters [message #25414 is a reply to message #25332] Wed, 10 September 2008 08:25 Go to previous message
I updated the page (to the best of my knowledge), please let me know if
the instructions does not work and I will change them.
> - henrik
>> Hi Guillaume,
>> need the the generated ssh keys, putty, etc.
>> do it yet. Sorry.
>> Regards,
>> Thomas Hallgren
>>> Best regards,
>>> Guillaume
>>>> Hi everyone,
>>>> Regards,
>>>> Guillaume
Previous Topic:Build system now checked into SVN
Next Topic:[buckminster-dev] PDE headless build of RCP headless product ... "The System Bundle's start lev
Current Time: Thu Jul 17 14:27:25 EDT 2025
Powered by FUDForum. Page generated in 0.08878 seconds
