Home » Archived » Riena » MasterDetailComposite
MasterDetailComposite [message #24995] Fri, 01 May 2009 16:00 Go to next message
Can I customize MasterDetailComposite?
* Hide or remove "New", "Remove", and "Apply" buttons?
* Have master table updated as I type in the detail widgets (instead of
when "Apply" is clicked)?
Re: MasterDetailComposite [message #25239 is a reply to message #24995] Sun, 03 May 2009 17:50 Go to previous messageGo to next message
MasterDetailComposite is relativly new. So there is currently no way to customize itself. You can subclass it and then
write your own widget (or at least the part that you like to be changed). This only requires you then to define a new
mapping between the widget to the original ridget. (http://wiki.eclipse.org/Riena_Custom_Ridgets)
And while you are add it, this can possibly mean that also need to subclass, rewrite the ridget code.
If you like to contribute or what to document your requirements in more detail, a bugzilla with that as a content is
always a good help. That is also a good place after a few discussion rounds to think about contributing a patch.
What we do have actually now that I think of it, is the option to have a different look for the buttons. If you look in
the example there under playground (subapplication) under playground (module) there is MasterDetail 2 (actually probably
not in 1.1.0.M6 but its in 1.1.0.M7 which we do next week or you can also checkout the sourcecode)
does that help ?
christian
Re: MasterDetailComposite [message #25323 is a reply to message #24995] Tue, 05 May 2009 02:46 Go to previous message
Originally posted by: eclipse-dev.volanakis.de
--------------080005050302080603070306
Hi Gabe,
yes, that's easy:
IMasterDetailsRidget ridget;
ridget.getRidget(MasterDetailsComposite.BIND_ID_APPLY).setVi sible(false);
// see MasterDetailsComposite for other constants
Theoretically yes - practically no. Two problems here:
(a) there is no official API;
(b) apply clears the details area
See the attached snippet for an example (not useful because of (b)).
Best open a bug with your requirements / use-case and we can continue
the discussion there.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Riena
Kind regards,
Elias.
name="Snippet.java"
Content-Disposition: inline;
filename="Snippet.java"
* Copyright (c) 2007, 2009 compeople AG and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* compeople AG - initial API and implementation
package org.eclipse.riena.sample.snippets;
import java.beans.PropertyChangeListener;
import org.eclipse.core.databinding.observable.list.WritableList;
import org.eclipse.jface.layout.GridDataFactory;
import org.eclipse.jface.layout.GridLayoutFactory;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
import org.eclipse.riena.beans.common.Person;
import org.eclipse.riena.beans.common.PersonFactory;
import org.eclipse.riena.internal.ui.ridgets.swt.MasterDetailsRidge t;
import org.eclipse.riena.ui.core.marker.ValidationTime;
import org.eclipse.riena.ui.ridgets.IMasterDetailsDelegate;
import org.eclipse.riena.ui.ridgets.IMasterDetailsRidget;
import org.eclipse.riena.ui.ridgets.IRidget;
import org.eclipse.riena.ui.ridgets.IRidgetContainer;
import org.eclipse.riena.ui.ridgets.ITextRidget;
import org.eclipse.riena.ui.ridgets.swt.SwtRidgetFactory;
import org.eclipse.riena.ui.ridgets.validation.NotEmpty;
import org.eclipse.riena.ui.swt.MasterDetailsComposite;
import org.eclipse.riena.ui.swt.utils.UIControlsFactory;
* A master details ridget. The master area shows a table of persons. The detail
* area can rename a person.
public final class Snippet {
private Snippet() {
// "utility class"
* A master details widget with a text fields for renaming a person.
private static final class PersonMasterDetails extends MasterDetailsComposite {
PersonMasterDetails(Composite parent, int style) {
super(parent, style, SWT.BOTTOM);
protected void createDetails(Composite parent) {
GridLayoutFactory.fillDefaults().numColumns(2).margins(20, 20).spacing(10, 10).equalWidth(false).applyTo(
parent);
GridDataFactory hFill = GridDataFactory.fillDefaults().grab(true, false);
UIControlsFactory.createLabel(parent, "Last Name:"); //$NON-NLS-1$
Text txtLast = UIControlsFactory.createText(parent);
hFill.applyTo(txtLast);
addUIControl(txtLast, "txtLast"); //$NON-NLS-1$
UIControlsFactory.createLabel(parent, "First Name:"); //$NON-NLS-1$
Text txtFirst = UIControlsFactory.createText(parent);
hFill.applyTo(txtFirst);
addUIControl(txtFirst, "txtFirst"); //$NON-NLS-1$
protected int getDetailsStyle() {
return SWT.BORDER;
* A IMasterDetailsDelegate that renames a person.
private static final class PersonDelegate implements IMasterDetailsDelegate {
private final Person workingCopy = createWorkingCopy();
public void configureRidgets(final IRidgetContainer container) {
ITextRidget txtLast = (ITextRidget) container.getRidget("txtLast"); //$NON-NLS-1$
txtLast.bindToModel(workingCopy, Person.PROPERTY_LASTNAME);
txtLast.addValidationRule(new NotEmpty(), ValidationTime.ON_UI_CONTROL_EDIT);
txtLast.updateFromModel();
ITextRidget txtFirst = (ITextRidget) container.getRidget("txtFirst"); //$NON-NLS-1$
txtFirst.bindToModel(workingCopy, Person.PROPERTY_FIRSTNAME);
txtFirst.updateFromModel();
PropertyChangeListener listener = new PropertyChangeListener() {
public void propertyChange(java.beans.PropertyChangeEvent event) {
System.out.println("pcl: " + event.getNewValue());
if (isValid(container) == null) {
// non API - use at own peril
// note that apply does deselect; so this is not very useful
((MasterDetailsRidget) container).handleApply();
txtLast.addPropertyChangeListener(ITextRidget.PROPERTY_TEXT, listener);
txtFirst.addPropertyChangeListener(ITextRidget.PROPERTY_TEXT , listener);
public Person copyBean(Object source, Object target) {
Person from = source != null ? (Person) source : createWorkingCopy();
Person to = target != null ? (Person) target : createWorkingCopy();
to.setFirstname(from.getFirstname());
to.setLastname(from.getLastname());
return to;
public Person createWorkingCopy() {
return new Person("", ""); //$NON-NLS-1$ //$NON-NLS-2$
public Person getWorkingCopy() {
return workingCopy;
public boolean isChanged(Object source, Object target) {
Person p1 = (Person) source;
Person p2 = (Person) target;
boolean equal = p1.getFirstname().equals(p2.getFirstname()) && p1.getLastname().equals(p2.getLastname());
return !equal;
public String isValid(IRidgetContainer container) {
if (txtLast.isErrorMarked()) {
return "'Last Name' is not valid."; //$NON-NLS-1$
return null;
public void updateDetails(IRidgetContainer container) {
for (IRidget ridget : container.getRidgets()) {
ridget.updateFromModel();
Display display = Display.getDefault();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
PersonMasterDetails details = new PersonMasterDetails(shell, SWT.NONE);
IMasterDetailsRidget ridget = (IMasterDetailsRidget) SwtRidgetFactory.createRidget(details);
ridget.setDelegate(new PersonDelegate());
WritableList input = new WritableList(PersonFactory.createPersonList(), Person.class);
String[] properties = { Person.PROPERTY_LASTNAME, Person.PROPERTY_FIRSTNAME };
String[] headers = { "Last Name", "First Name" }; //$NON-NLS-1$ //$NON-NLS-2$
ridget.bindToModel(input, Person.class, properties, headers);
* Hide the REMOVE and APPLY buttons
ridget.getRidget(MasterDetailsComposite.BIND_ID_REMOVE).setV isible(false);
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
--------------080005050302080603070306--
Re: MasterDetailComposite [message #582155 is a reply to message #24995] Sun, 03 May 2009 17:50 Go to previous message
does that help ?
christian
Re: MasterDetailComposite [message #582188 is a reply to message #24995] Tue, 05 May 2009 02:46 Go to previous message
Hi Gabe,
yes, that's easy:
Kind regards,
Elias.
name="Snippet.java"
* Contributors:
private Snippet() {
// "utility class"
parent);
return SWT.BORDER;
return to;
return workingCopy;
return !equal;
return null;
shell.pack();
shell.open();
display.sleep();
display.dispose();
Previous Topic:Eclipse Stammtisch in Frankfurt/Main 27.May.2009
Next Topic:1.1.0.M7 delayed
Current Time: Fri Jul 18 19:12:27 EDT 2025
Powered by FUDForum. Page generated in 0.04093 seconds
