Home » Language IDEs » Java Development Tools (JDT) » org.eclipse.jdt.ui.javaCompletionProposalComputer
org.eclipse.jdt.ui.javaCompletionProposalComputer [message #252963] Thu, 24 April 2008 04:56 Go to next message
Originally posted by: reg.zhuce.163.com
I use this extention point to give some completion proposals.
And I have implemented the IJavaCompletionProposalComputer.
But it does not work.
Is it enough to make the plug-in launched whenever the completion action
is triggered?
or is there any more configurations I must make?
By the way, may I define some special auto-activation-characters only
for my plug-in?
Re: org.eclipse.jdt.ui.javaCompletionProposalComputer [message #252968 is a reply to message #252963] Thu, 24 April 2008 05:23 Go to previous messageGo to next message
> is triggered?
Not sure what you mean.
If you want your plug-in to be activated then you need to add the
following attribute, as outlined in the doc:
activate="true"
> for my plug-in?
No, you cannot do this as this is a user preference which you shouldn't
modify.
Dani
Re: org.eclipse.jdt.ui.javaCompletionProposalComputer [message #252978 is a reply to message #252968] Thu, 24 April 2008 11:09 Go to previous messageGo to next message
Daniel Megert 写道:
>> is triggered?
> activate="true"
Thank you.
I just mean I have completed plugin.xml and an class implementing the
IJavaCompletionProposalComputer, which is the value of the "class
"attribute for this extention point.
And your suggestion is to the point.The plug-in is launched.
But the method computeCompletionProposals is never called.So it still
can not show any proposals.
>> for my plug-in?
> modify.
Then I have no way to differentiate the auto-activation-character for
different CompletionProposalComputers?
I do not want the proposals showed after a character like '.'.
> Dani
Re: org.eclipse.jdt.ui.javaCompletionProposalComputer [message #252981 is a reply to message #252978] Thu, 24 April 2008 11:54 Go to previous messageGo to next message
dazh wrote:
> Daniel Megert 写道:
>>> is triggered?
>> activate="true"
> Thank you.
Maybe you did not add your computer to the default category. If so, you
first need to enable it on the Java > Editor > Content Assist > Advanced
pref page.
>>> for my plug-in?
>> modify.
Your computer returns the proposals and you know where the completion is
inserted. Simply check whether it is a '.' and then don't return proposals.
Dani
>> Dani
Re: org.eclipse.jdt.ui.javaCompletionProposalComputer [message #252990 is a reply to message #252981] Thu, 24 April 2008 12:27 Go to previous messageGo to next message
Daniel Megert 写道:
> dazh wrote:
>> Daniel Megert 写道:
>>>> is triggered?
>>> activate="true"
>> Thank you.
> pref page.
But it has already been checked.
Is there any other possibility?
>>>> for my plug-in?
>>> modify.
That sounds to lose some efficiency.
Any way,it is a useful solution.
Thanks again.
> Dani
>>> Dani
Re: org.eclipse.jdt.ui.javaCompletionProposalComputer [message #253007 is a reply to message #252981] Sat, 26 April 2008 07:10 Go to previous messageGo to next message
Daniel Megert 写道:
> dazh wrote:
>> Daniel Megert 写道:
>>>> is triggered?
>>> activate="true"
>> Thank you.
> pref page.
>>>> for my plug-in?
>>> modify.
Another question in the opposite direction:
Is it possible to prevent the built-in proposals showing after the
characters I add?
> Dani
>>> Dani
Re: org.eclipse.jdt.ui.javaCompletionProposalComputer [message #253011 is a reply to message #253007] Sat, 26 April 2008 08:46 Go to previous message
dazh wrote:
> Daniel Megert 写道:
>> dazh wrote:
>>> Daniel Megert 写道:
>>>>> is triggered?
>>>> activate="true"
>>> Thank you.
>> pref page.
>>>>> for my plug-in?
>>>> modify.
> characters I add?
No.
Dani
>> Dani
>>>> Dani
Previous Topic:Compiler compliance level
Next Topic:markerAnnotationSpecification does not work
Current Time: Tue Oct 14 10:12:24 EDT 2025
Powered by FUDForum. Page generated in 0.05330 seconds
