Home » Newcomers » Newcomers » Externalize Strings Wizard - Are There Any Preference Settings
Externalize Strings Wizard - Are There Any Preference Settings [message #252878] Tue, 01 April 2008 14:45 Go to next message
Whenever I run the Externalize Strings Wizard it always defaults the
accessor settings to the current package I'm working in. What I really
want is to set a global default for the accessor settings to a common
package in my application. Is there a way to do this?
Re: Externalize Strings Wizard - Are There Any Preference Settings [message #252895 is a reply to message #252878] Wed, 02 April 2008 02:50 Go to previous messageGo to next message
There are no global preference but the dialog has a history. You can
select the last 'Accessor class:' from the drop down.
Dani
Re: Externalize Strings Wizard - Are There Any Preference Settings [message #252958 is a reply to message #252895] Wed, 02 April 2008 13:56 Go to previous messageGo to next message
> Dani
Thanks for the tip. That helps, but a preference setting would be
preferred :-)
Cheers, Eric
Re: Externalize Strings Wizard - Are There Any Preference Settings [message #252970 is a reply to message #252958] Wed, 02 April 2008 16:07 Go to previous messageGo to next message
> preferred :-)
File an enhancement request :)
~ Chris
Re: Externalize Strings Wizard - Are There Any Preference Settings [message #252986 is a reply to message #252970] Wed, 02 April 2008 18:06 Go to previous message
> Cheers,
> ~ Chris
Done!
Thanks, Eric
Previous Topic:seeing double in code assistant
Next Topic:What's the standard term for the behavior of the little (i) icons and tool tip that shows next to a
Current Time: Wed Sep 17 22:53:26 EDT 2025
Powered by FUDForum. Page generated in 0.31672 seconds
