Home » Language IDEs » Java Development Tools (JDT) » How to get a TextViewer from IEditorPart ?
How to get a TextViewer from IEditorPart ? [message #252694] Wed, 16 April 2008 11:51 Go to next message
Originally posted by: reg.zhuce.163.com
It's in the method:
public void setActiveEditor(IAction action, IEditorPart targetEditor).
Re: How to get a TextViewer from IEditorPart ? [message #252701 is a reply to message #252694] Wed, 16 April 2008 12:17 Go to previous messageGo to next message
dazh 写道:
> It's in the method:
I know I can do like this:
((JavaEditor)targetEditor).getViewer()
But it's told
"Discouraged access: The type JavaEditor is not accessible due to
restriction on
required library"
Is there any way alternative?
Re: How to get a TextViewer from IEditorPart ? [message #252733 is a reply to message #252701] Thu, 17 April 2008 04:26 Go to previous messageGo to next message
dazh wrote:
> dazh 写道:
>> It's in the method:
> But it's told
> restriction on
> required library"
No. The viewer must not be accessed unless it is your own editor.
Dani
Re: How to get a TextViewer from IEditorPart ? [message #252742 is a reply to message #252733] Thu, 17 April 2008 09:15 Go to previous messageGo to next message
Daniel Megert 写道:
> dazh wrote:
>> dazh 写道:
>>> It's in the method:
>> But it's told
>> restriction on
>> required library"
> Dani
Then if I want to customize ContentAssistant which has to access viewer,
I must implement a editor?
That's terrible.
Re: How to get a TextViewer from IEditorPart ? [message #252793 is a reply to message #252742] Fri, 18 April 2008 03:06 Go to previous messageGo to next message
dazh wrote:
> Daniel Megert 写道:
>> dazh wrote:
>>> dazh 写道:
>>>> It's in the method:
>>> But it's told
>>> restriction on
>>> required library"
>> Dani
> Thanks
> That's terrible.
No it is not. You can register a completion proposal computer via
extension point.
Dani
Re: How to get a TextViewer from IEditorPart ? [message #252917 is a reply to message #252793] Wed, 23 April 2008 05:52 Go to previous messageGo to next message
Daniel Megert 写道:
> dazh wrote:
>> Daniel Megert 写道:
>>> dazh wrote:
>>>> dazh 写道:
>>>>> It's in the method:
>>>> But it's told
>>>> restriction on
>>>> required library"
>>> Dani
>> Thanks
>> That's terrible.
> extension point.
> Dani
Really? That's exiting.
I tried a lot of extension points, such as
org.eclipse.jdt.ui.javaCompletionProposalComputer.
But it throws exceptions, and I do not know why at all.
How can I realize it via extension point? Would you give any details?
Re: How to get a TextViewer from IEditorPart ? [message #252939 is a reply to message #252917] Wed, 23 April 2008 12:16 Go to previous messageGo to next message
dazh wrote:
> Daniel Megert 写道:
>> dazh wrote:
>>> Daniel Megert 写道:
>>>> dazh wrote:
>>>>> dazh 写道:
>>>>>> It's in the method:
>>>>> But it's told
>>>>> restriction on
>>>>> required library"
>>>> Dani
>>> Thanks
>>> That's terrible.
>> extension point.
>> Dani
Just look how other do it, e.g. jdt.ui itself uses the extension point.
So, I suggest you start there.
Dani
Re: How to get a TextViewer from IEditorPart ? [message #252956 is a reply to message #252939] Thu, 24 April 2008 03:03 Go to previous message
Daniel Megert 写道:
> dazh wrote:
>> Daniel Megert 写道:
>>> dazh wrote:
>>>> Daniel Megert 写道:
>>>>> dazh wrote:
>>>>>> dazh 写道:
>>>>>>> It's in the method:
>>>>>> But it's told
>>>>>> restriction on
>>>>>> required library"
>>>>> Dani
>>>> Thanks
>>>> That's terrible.
>>> extension point.
>>> Dani
> Dani
Thank you for your suggestion.
In fact,I have looked lots of code before I asked here.
I have fixed the exception.
But it seems that the plug-in isn't loaded at all.
How can I trigger it?
What's more, how can I define other auto-activation-characters different
from the built-in ones, such as '#'?
Previous Topic:Is there any extension points for JavaSourceViewerConfiguration
Next Topic:java parser
Current Time: Tue Sep 16 13:18:52 EDT 2025
Powered by FUDForum. Page generated in 0.05679 seconds
