Home » Eclipse Projects » Eclipse Platform » Two questions re: hot code replacement and runtime workbench
Two questions re: hot code replacement and runtime workbench [message #252432] Mon, 14 June 2004 15:14 Go to next message
Originally posted by: bdkucer.sandia.gov
I tried to post this in a thread I already started, but it won't let me
for some reason.
1) Hot Code Replacement has suddenly stopped working for me. I used it
last Friday, but today when I change, save, and rebuild plugin code that
I'm working on nothing happens in the runtime workbench. Any ideas?
2) How do I make the runtime workbench start faster? I've heard that I
should remove plugins I'm not using, but how do I do that?
Re: Two questions re: hot code replacement and runtime workbench [message #252883 is a reply to message #252432] Tue, 15 June 2004 17:10 Go to previous message
Originally posted by: john.eclipsefaq.org
You can control what plugins are launched from the launch configuration
dialog (Run > Run...). The Plugins tab lets you choose which plugins you
want. Also, unchecking the "Clear configuration area before launching"
in the Configuration tab is also likely to speed up your launches.
> for some reason.
Previous Topic:How to hook a plugin with IMenuListener
Next Topic:Suggestion for Outline View
Current Time: Sun Jul 27 08:10:32 EDT 2025
Powered by FUDForum. Page generated in 0.03381 seconds
