Home » Language IDEs » Java Development Tools (JDT) » How to avoid Java 5.0 code templates
How to avoid Java 5.0 code templates [message #252341] Tue, 01 April 2008 03:30 Go to next message
I am currently setting the java compiler compliance level to jdk 5.0
However, I do not want the editor to insert annotations nor generics when
I type.
Can this be done? How?
Mariano.
Re: How to avoid Java 5.0 code templates [message #252345 is a reply to message #252341] Tue, 01 April 2008 03:33 Go to previous messageGo to next message
Mariano Eloy Fernández wrote:
> when I type.
Why do you set the level to 5.0 then?
Dani
> Mariano.
Re: How to avoid Java 5.0 code templates [message #252484 is a reply to message #252345] Tue, 08 April 2008 06:04 Go to previous messageGo to next message
I guess I want to compile with 5.0 compliance becouse I will be running on
a 5.0 JRE. I just don't want to use generics nor annotations.
Re: How to avoid Java 5.0 code templates [message #252487 is a reply to message #252484] Tue, 08 April 2008 07:34 Go to previous message
Mariano,
Stuff compiled for 1.4 compliance will run with 5.0 just as well...
> running on a 5.0 JRE. I just don't want to use generics nor annotations.
Previous Topic:Possible to extend Package Explorer to allow DnD of other objects onto a Java package?
Next Topic:F1 not working in Package Explorer
Current Time: Fri Nov 07 08:33:43 EST 2025
Powered by FUDForum. Page generated in 0.04351 seconds
